Author Topic: Gauge cluster fuse  (Read 4733 times)
Snigalfriz
    • 1991 NA Capri
Gauge cluster fuse
« on: October 31, 2011, 07:27:00 PM »
Anyone know which fuse is the gauge cluster fuse?
1991 Mercury Capri 5-sp
1992 Mercury Capri 5-sp swap
1999 Ford Contour SE 24v v6
2003 Lincoln LS
2007 Saturn Outlook XE AWD
2014 Chevy Cruze LT
Gauge cluster fuse
« Reply #1 on: November 01, 2011, 04:32:00 AM »
The 10 amp METER fuse
engine---stop-----windows
xxxxxx---meter----hazard
htd------cigar----tail
room-----doorlock-audio
xxxxxx---fog------air cond
xxxxxx---cool fan-wiper
...Chris
Snigalfriz
    • 1991 NA Capri
Gauge cluster fuse
« Reply #2 on: November 01, 2011, 04:50:00 AM »
Thanks Chris
2003 Lincoln LS
2014 Chevy Cruze LT
Snigalfriz
    • 1991 NA Capri
Gauge cluster fuse
« Reply #3 on: November 02, 2011, 09:23:00 AM »
All the fuses are are good, it may just be the dimmer switch is bad.  Ordered one earlier.
2003 Lincoln LS
2014 Chevy Cruze LT
Snigalfriz
    • 1991 NA Capri
Gauge cluster fuse
« Reply #4 on: November 05, 2011, 09:02:00 PM »
Nope, still no lights
2003 Lincoln LS
2014 Chevy Cruze LT
Gauge cluster fuse
« Reply #5 on: November 06, 2011, 03:15:00 AM »
If it isn't the dimmer switch, and the fuses are all good, I would try the headlight switch next........
Snigalfriz
    • 1991 NA Capri
Gauge cluster fuse
« Reply #6 on: November 07, 2011, 02:23:00 AM »
Cool, I have one on the way. I should get it in a couple days.
Thanks
2003 Lincoln LS
2014 Chevy Cruze LT
luvit
  • imluvit
    • 93capri na
Gauge cluster fuse
« Reply #7 on: November 15, 2011, 05:13:00 AM »
yep, headlight switch.
if your main front beams light-up flip the swith back down one notch and see if the cluster lights-up.
remember, if you have no cluster lights, you have no tail lights..
omgimluvit
Snigalfriz
    • 1991 NA Capri
Gauge cluster fuse
« Reply #8 on: November 16, 2011, 03:37:00 AM »
Changed the headlight switch, and still no gauge lights.
Any idea how many bulbs are used to light up the gauge cluster?
2003 Lincoln LS
2014 Chevy Cruze LT
luvit
  • imluvit
    • 93capri na
Gauge cluster fuse
« Reply #9 on: November 18, 2011, 01:15:00 AM »
First, make sure you have tail lights while your headlights are powered on.. to make sure you're not chasing a goose.
omgimluvit
Snigalfriz
    • 1991 NA Capri
Gauge cluster fuse
« Reply #10 on: November 18, 2011, 03:39:00 AM »
I have taillights when the headlights are on.
2003 Lincoln LS
2014 Chevy Cruze LT
Gauge cluster fuse
« Reply #11 on: November 19, 2011, 06:10:00 AM »
There is a Panel Lamp Control Module, sits behind the gauge cluster, the dimmer connects directly to it.  Supplies voltage to all the gauge lights, might be bad.
http://www.use.com/94_capri_component_locations_02c77117134dad9a6510
Check out page 151-5 for location... Chris
Snigalfriz
    • 1991 NA Capri
Gauge cluster fuse
« Reply #12 on: November 21, 2011, 05:11:00 AM »
I will give that a look.  Is there a fuse in it that can be replaced?
2003 Lincoln LS
2014 Chevy Cruze LT
Snigalfriz
    • 1991 NA Capri
Gauge cluster fuse
« Reply #13 on: December 18, 2011, 08:17:00 AM »
Does anyone have a pic of the module?
2003 Lincoln LS
2014 Chevy Cruze LT
