Author Topic: 91 with no heat  (Read 4515 times)
hartlmeier
91 with no heat
« on: March 07, 2009, 09:04:00 AM »
It is early for my capri this year(mountaieer needs timing chain) and no heat in the capri
91 with no heat
« Reply #1 on: March 07, 2009, 09:53:00 AM »
clogged bypass likes to the heater core or the core itself is bad.
i have same issue and waiting until the end of summer to fix it. 80's here in phoenix so no need to waist money on something not being used..LOL
i was so happy when the air did work
hartlmeier
91 with no heat
« Reply #2 on: March 07, 2009, 11:33:00 AM »
thanks
91 with no heat
« Reply #3 on: March 07, 2009, 05:34:00 PM »
Hey Hart! Pull the hoses off at the motor and run water from a garden hose to check flow and also flush out the core. Pay attention to what flows out and also the flow rate. Good Luck  Gus
91 with no heat
« Reply #4 on: March 07, 2009, 05:40:00 PM »
Hey Hart! I closed my post before I was done with my thought. When you're done flushing and put it back together and check for heat, if still no heat then check temp of hoses; if they are hot then you have to check the doors under the dash for operation. They may not be working because of a broken cable or other.  Gus
hartlmeier
91 with no heat
« Reply #5 on: March 08, 2009, 09:04:00 AM »
I will check it out Thanks for the help
91 with no heat
« Reply #6 on: March 09, 2009, 06:00:00 PM »
never thought about the water hose thing...
