Tech, Repairs, Upgrades => Capri N/A 89-94 => Topic started by: hartlmeier on March 07, 2009, 09:04:00 AM
It is early for my capri this year(mountaieer needs timing chain) and no heat in the capri
clogged bypass likes to the heater core or the core itself is bad.
i have same issue and waiting until the end of summer to fix it. 80's here in phoenix so no need to waist money on something not being used..LOL
i was so happy when the air did work
thanks
Hey Hart! Pull the hoses off at the motor and run water from a garden hose to check flow and also flush out the core. Pay attention to what flows out and also the flow rate. Good Luck Gus
Hey Hart! I closed my post before I was done with my thought. When you're done flushing and put it back together and check for heat, if still no heat then check temp of hoses; if they are hot then you have to check the doors under the dash for operation. They may not be working because of a broken cable or other. Gus
I will check it out Thanks for the help
never thought about the water hose thing...
