So if I'm following this correctly, the "top to bottom" IC, like this one,
http://www.siliconeintakes.com/front-mount-intercooler/top-to-bottom-intercooler-p-208.html?osCsid=6783a0233c5a45624f0ff5ed9f5d928d , should be a suitable replacement for the stock XR2 IC unit? I realize it's about twice the height and over twice the width, but is there room in the area where the stock IC is for something like this to fit, and still keep the AC and anything else that's around that area? The reason I'm asking is I put an FMIC on a Saab 900 classic turbo I used to have, and it was a nightmare. I had to remove the headlight wiper motors to route the piping, cut up the bumper, and cut up some other metal to get it to fit properly. I'd rather not have to do that with the XR2.
If my math is correct, the surface area of the stock IC is about 58 square inches, with a volume around 144 cubic inches. This bigger IC has a surface area of 237 square inches, with a volume around 830 cubic inches. So this newer IC has 4 times the surface area and almost 6 times the volume?! That's gotta do wonders for the charge going to the intake!
I'm probably going to remove the stock airbox and fit a Uni dual stage foam filter on the MAF sensor, and really think hard about this bigger IC. At "only" $170 for the IC, and probably having to get a pair of straight 2.5" couplers and a pair of 90-degree elbows to connect to the stock soft pipes, this should give a lot of bang for the buck, provided it's not an absolute nightmare to install?
