Author Topic: Suspension Bushings  (Read 3227 times)
Tim
Suspension Bushings
« on: July 19, 2004, 06:43:00 AM »
Does anyone know where to get front & rear suspension bushings for a '91 XR2?  I have haven't found anything in the archives.  I've check with Corksport, Summit, JC Whitney (formerly Stylin' Compacts), and a couple other places that turned up on Google: no luck.
Thanks
Tim in St. Louis
\\\'91 XR2 White
Reich Racing cold air intake and re-mapped ECM, 2.5\\" manifold back exhaust, boostvalve, Borbet 16\\" whls, Kumho tires, Tokico struts, H&R springs, front strut tower bar
STE_6000
    • http://teamcapri.com
Suspension Bushings
« Reply #1 on: July 19, 2004, 06:12:00 PM »
Not sure, i can tell you mount points kyb sells, look up custom bushings or just try a pepboys or some local car parts shop.
Anthony
-Tinted Windows 20%
-Volant Cold Air Intake
-Corsa Exhaust
Suspension Bushings
« Reply #2 on: July 28, 2004, 08:50:00 AM »
Do you mean the sway bar linkage bushings? I got front and rear from the local mercury dealer last fall, I think around $20 a pop. also, mccm (http://www.midcomustang.com) probably has em.
91 xr2
Quote
Thanks
mhack
    • http://akdusa.com/xr2
Suspension Bushings
« Reply #3 on: August 23, 2004, 08:22:00 AM »
Try www.corksport.com they have bushings for 323 GTX.
  • Cone Air Filter (3\\" tube)
Khanmicro
Suspension Bushings
« Reply #4 on: March 16, 2005, 06:41:00 PM »
Did you ever find a source for your suspension bushings?
Thanks
Mike
need4speed428
2007 Toyota Tacoma 4x4
1966 F100
yen
Suspension Bushings
« Reply #6 on: November 16, 2008, 05:13:00 PM »
i think last i checked whiteline had them. its been a while though...
the bushings aand sway bar are next on my to get list. there is no space on the to do list anymore, everything needs afixing
1990 Ford Capri
1.6L SOHC
