May 11, 2024, 09:50:06 AM
Welcome,
Guest
Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
Home
Help
Search
Login
Register
General
General
What should be there?
« previous
next »
Pages: [
1
Print
Author
Topic: What should be there? (Read 3532 times)
CapriProject
Full Member
on:
July 20, 2010, 07:39:00 AM »
In the engine compartment, Driver's side on inner fender. What was held there with a black attached 'cable-tie' & connected to the wire harness? Here's a piture.
Administrator
Old-Timer
91 BPT AWD Capri & 1991 XR2
Reply #1 on:
July 20, 2010, 07:48:00 AM »
If the one on the left is just a single wire, its a connector for any diagnostic equipment that requires a tach signal. It should be close to the connector for the ignition coil.
The other one might be a connector for the cruise control servo?
CapriProject
Full Member
Reply #2 on:
July 20, 2010, 11:20:00 AM »
A cruise control servo... Both the black 'cable tie' & the 3 or 4 wire connector are secured to the metal fender. sound right to you?
Yes, the single one would be a 'test' connecton like you said.
Old-Timer
Reply #3 on:
July 20, 2010, 12:13:00 PM »
Matt is right on!
Clay
Print
Pages: [
1
« previous
next »
General
General
