General => General => Topic started by: CapriProject on July 20, 2010, 07:39:00 AM
In the engine compartment, Driver's side on inner fender. What was held there with a black attached 'cable-tie' & connected to the wire harness? Here's a piture. (http://farm5.static.flickr.com/4142/4812509113_dc23e69d46.jpg)
If the one on the left is just a single wire, its a connector for any diagnostic equipment that requires a tach signal. It should be close to the connector for the ignition coil.
The other one might be a connector for the cruise control servo?
A cruise control servo... Both the black 'cable tie' & the 3 or 4 wire connector are secured to the metal fender. sound right to you?
Yes, the single one would be a 'test' connecton like you said.
Matt is right on!
Clay
