Tech, Repairs, Upgrades > Engine & Drivetrain Swaps
91 turbo into 94 na
DarkAngel:
Yes, the engine harness was different for the 91 and the 94...
The issue was also the ECU connections... the sparky put a new harness into the ECU... Some of the sensors had to get wired in I think.
chrispoe:
--- Quote from: greywolf27030 on April 24, 2017, 04:42:56 PM ---
--- Quote from: Casper on November 23, 2016, 01:42:58 AM ---Always tricky when transplanting engines.....I would like to do the same with my N/A but I would like to go down the electric route at some stage when batteries bet better for DIY conversions.
See the link for a capri converted in Adelaide to electric - interesting stuff....
http://evalbum.com/4073
--- End quote ---
Great writeup. I agree. I think the Capri would be an excellent vehicle to convert to electric.
--- End quote ---
If I was doing a electric conversion to a Capri, I would leave the original fwd drivetrain in place.
I would go the hybrid route and use a GTX rear setup. Modify it so the differential input faces the rear and install a right angle gearbox to it so the motor would stick up vertically in the center of the trunk. Then remove the backseat and use that space for the battery pack/freq drive to operate the motor.
IMHO... this would be the ultimate AWD setup.
Navigation
[0] Message Index
[*] Previous page
Go to full version
