Author Topic: xr2 lsd?  (Read 2871 times)
ricky
xr2 lsd?
« on: October 16, 2008, 10:29:00 PM »
does the xr2 have a lsd from factory..  every time ive done a burn out ive left 2 very dark very long lines..
xr2 lsd?
« Reply #1 on: October 17, 2008, 06:00:00 AM »
Hey Ricky! No Lsd is available that I'm aware of. There is one that with some grinding of the case and some axle mods can be installed. Gus
bryanknight
xr2 lsd?
« Reply #2 on: October 17, 2008, 05:20:00 PM »
is there anything i can do to help mine hook up and leave to black marks mine well just spen the right side of the car the half shaft side ?? i need both to have fun
Phillip
xr2 lsd?
« Reply #3 on: October 28, 2008, 10:18:00 AM »
I have the same thing going on with mine both tires are loosing traction. I know both are spinning because I see the rubber, hear the squeal and when it is even the slightest wet out from a stop it takes off sideways (to the passenger side). It's not torque steer the steering wheel stays straight.
1992xr2
xr2 lsd?
« Reply #4 on: October 28, 2008, 11:24:00 AM »
When the available traction is equal on both sides an open differential will spin both tires on a car with even front cross weights.  The advantage to lsd is that even if one side of the car is in the air (cornering very quickly) the other can still put power down.  For drag racing a lsd is very little advantage, this guy from HMT is putting down 1.6 60 fts with an open diff and a SOHC.
NSFW  HMT 1.6 60fts
\\\'90 Civic Si
Boost in the near future.
