Author Topic: clutch linkage  (Read 3922 times)
bobbynahas
clutch linkage
« on: November 17, 2010, 08:24:00 AM »
I have a real high pedal, a few of you told me that it can be adjusted. can you tell me where it is and how to do it?
clutch linkage
« Reply #1 on: November 17, 2010, 04:16:00 PM »
Supposedly there's adjusters on the transmission, and one at the pedal.
Of course this applies to the turbo models though, non-turbo I'm not too familiar.  The transmission one you'll probably need the battery out to get to though.
clutch linkage
« Reply #2 on: November 17, 2010, 05:53:00 PM »
On the turbo its on the top&front of the transmission, its right under the airbox. You can get to it without removing anything, but its a little tricky.
bobbynahas
clutch linkage
« Reply #3 on: November 18, 2010, 07:56:00 AM »
tricky how? thanks agian
clutch linkage
« Reply #4 on: November 18, 2010, 01:21:00 PM »
Tight squeeze if you leave the stock airbox & piping in place.
