Author Topic: More Capri parts, whole engines, etc  (Read 3470 times)
« on: October 31, 2011, 07:57:00 PM »
I have a couple more things:
1x set silver foglight grill inserts $40 shipped
1x 94only R134a AC compressor $150 shipped
1x wiper motor $40 shipped
1x B6T VAF - $70 shipped
1x OEM B6T Bypass valve $15 shipped
1x OEM B6T Ignition coil $25
1x Capri 70A Alternator $75 shipped
1x B6D/B6T throttlebody NO tps $35
1x B6T manifold heat shield in decent shape $40 shipped
1x Full B6T engine harness w/ firewall sensors, main/pump relay, and stock ECU $250...willing to negotiate a chip w/ harness & ecu
Rust free subframe:
$75?
Also have a DOHC Capri B6D "half--short-block"
Been sitting a while but perfectly usable. Missing crank, oil pump, oil pan. Minor rust on top of bores. Pistons & rods still present, pistons are 9.0:1. great candidate for a build project, drilled & tapped for turbo duty
$100, delivery available
I am picking up 3 engines, 3 transmissions, and a couple other items on Wednesday.
-DOHC B6D w/ approx 180k, 9.0:1 compression. Complete longblock, came from running car. Large nose crank
-DOHC B6D w/ approx 170k, 9.4:1 compression. Complete longblock, came from running car. Not sure which crank yet
-B6T longblock w/ 84k miles. W/ matching 84k G-type transmission. No turbo, Large nose crank.
-1x XR2 g-type transmission, approx. 150k miles
-N/A Capri hydro F-Type 5-speed, approx 170k miles
-1x B6T Head w/ cams
-2x full sets of XR2 axles inc. intermediate shafts
-3x full sets of XR2 knuckle assemblies w/ rotor & calipers
Need to confirm mileage, and get pictures. Will update
billibarou
« Reply #1 on: November 03, 2011, 03:23:00 PM »
I could really use a power steering pump bolt if you could pick one up?
« Reply #2 on: November 03, 2011, 07:53:00 PM »
The lower pivot bolt or the tensioner bolt?
billibarou
« Reply #3 on: November 04, 2011, 07:00:00 AM »
I need the tensioner bolt and the bolt it goes into...please let me know how much?
« Reply #4 on: November 04, 2011, 02:03:00 PM »
I have one, I just need to find it
« Reply #5 on: November 05, 2011, 07:05:00 AM »
Got it. $10 shipped?
Rabbit-Rabbit
« Reply #6 on: November 06, 2011, 08:55:00 AM »
I Need a IAC Valve for a 1993 Capri!
« Reply #7 on: November 06, 2011, 10:46:00 AM »
I have several! Please email me at rocketman@werbatfik.com
billibarou
« Reply #8 on: November 06, 2011, 11:15:00 PM »
$10 would be great...how do I pay you I have paypal or I can send you a check?
« Reply #9 on: November 08, 2011, 03:04:00 AM »
Paypal works - I accept Paypal to rocketman[AT]werbatfik.com please be sure to send me your address
« Last Edit: June 09, 2014, 02:37:00 PM by Rocketman »
frobro85
« Reply #10 on: November 12, 2011, 07:14:00 PM »
Still have the b6t long nose and tranny? and if so how much.
« Reply #11 on: November 13, 2011, 08:41:00 AM »
Yes I do! I will PM you
