Pages: 1 ... 5 6 [7] 8 9 ... 25
Author Topic: My Capri  (Read 122260 times)
icurunnin
My Capri
« Reply #90 on: November 01, 2009, 02:14:00 AM »
great example Joe. as long as they can clear that new box you made go with it. if not, I would make the new box work with the seat belts. your safety is far more important than being heard.
my   .02
3 92 Galant VR-4\\\'s = sold
89 I-Mark RS = sold
91 Impulse RS = sold
3 95 TSI AWD talons = sold
93 TSI AWD talon = sold
89 Colt GT = sold
91 Capri XR2 = sold
yeah, there\\\'s more....
My Capri
« Reply #91 on: November 01, 2009, 03:57:00 AM »
run the straps straight back to there the back seatbelts bolted in
Heavensheros
My Capri
« Reply #92 on: November 01, 2009, 09:45:00 AM »
Ok so after further review i have fixed the problem while keeping the speaker box and keeping everything looking good like it should. here are some updated pics.
Bolted down to the old seat belt bolts so they are nice and strong
The slot will soon be cleaned up with some metal outline to protect the wood and the seat belt
The finished look !!!
Also cut away at the old panel and that area is where the new optima dry cell battery will go when i do the battery relocation.
1992 Capri XR2
RocketMan VAF adaptor
Accel wires
Irundium IX
2.5\\" Thrush exauhst
Rocket Chip
Rims
H&R Lowering Springs
Tuner FX Racing seats
Gauges w/ A-pillar gauge pods
Accel superstock coil
FMIC
icurunnin
My Capri
« Reply #93 on: November 01, 2009, 11:00:00 AM »
much better
89 I-Mark RS = sold
89 Colt GT = sold
91 Capri XR2 = sold
My Capri
« Reply #94 on: November 01, 2009, 11:52:00 AM »
just like i said..LOL
Heavensheros
My Capri
« Reply #95 on: November 01, 2009, 11:59:00 AM »
thank you for the great ideas
1992 Capri XR2
Accel wires
Irundium IX
Rocket Chip
Rims
FMIC
My Capri
« Reply #96 on: November 01, 2009, 12:53:00 PM »
better, but is that wood, that the box is made of strong enough? so that in an accident it wouldnt crush and defaultly loosten up the harnesses a bit.. like would the speakerbox slide forward in an accident? loostening the belts??
i dunno maybe, it is, but safety comes first!!!
Heavensheros
My Capri
« Reply #97 on: November 01, 2009, 02:42:00 PM »
the belts are tight down the the bolt that they are bolted down to ... when i tighten the belts they are tight because of the belt .. the wood is strong and wont crush and the box is in place tightly because of the roll bars and weight. if slammed on the brakes to test the box and it does not move.
1992 Capri XR2
Accel wires
Irundium IX
Rocket Chip
Rims
FMIC
Heavensheros
My Capri
« Reply #98 on: November 01, 2009, 02:44:00 PM »
the box does its job by hold the seatbelts back. i used very strong oak planks for that job i will also be putting metal around those slots to improve looks and functionality
1992 Capri XR2
Accel wires
Irundium IX
Rocket Chip
Rims
FMIC
Heavensheros
My Capri
« Reply #99 on: November 01, 2009, 02:46:00 PM »
RCI what brand is your seats ?
1992 Capri XR2
Accel wires
Irundium IX
Rocket Chip
Rims
FMIC
Heavensheros
My Capri
« Reply #100 on: November 07, 2009, 11:52:00 AM »
well i got the wire removed and the new wire wired up to the fuse and starter. need to get the wire ran and everything finished ... post pics later tonight
1992 Capri XR2
Accel wires
Irundium IX
Rocket Chip
Rims
FMIC
Heavensheros
My Capri
« Reply #101 on: November 09, 2009, 02:03:00 PM »
Here is an update on the battery move so far... been working kind of slow, working little bit each day.
I removed entire ground wire going from battery to engine and chassis and also the power wire going from battery to starter and main fuse.
Wire going from distribution block to fuse.
Wire going from Distribution box to starter motor
Distribution box
The wires all tired up together ready to be covered with electrical tape to clean it all up
The main power wire in the wire conduit, running along the frame rail.
Hole where the wire comes through the floor and also the battery box mounted securely to the floor.
1992 Capri XR2
Accel wires
Irundium IX
Rocket Chip
Rims
FMIC
Heavensheros
My Capri
« Reply #102 on: November 14, 2009, 04:00:00 PM »
Here is a pic of the engine bay dismantled and the new valve cover !!
Dismantled engine
New valve cover ... after sand blasting and paint she looks very good !!
1992 Capri XR2
Accel wires
Irundium IX
Rocket Chip
Rims
FMIC
My Capri
« Reply #103 on: November 14, 2009, 04:13:00 PM »
not bad....i have had a cover sitting in the garage for months and i am just too lazy to polish it up...then the 94 came into my life and i been tackling that conversion...guess i am saving the engine for last..
keep up the good work! I hope to have another car in Jan so i can part the capri to do some things..its a DD so hard as hell to do anything intensive.
My Capri
« Reply #104 on: November 14, 2009, 04:57:00 PM »
josh i can see why you painted your dash while still in the car....
i took the one out of the 94 today..there has to be an easier way...the frame and everything came out with it. i am now rethinking taking mine out and just paint it while its still in the car.
