Tech, Repairs, Upgrades => Non-Capri Usable Car Parts => Topic started by: Jim on July 12, 2003, 05:30:00 PM
Title: Manual transmission shift rod bushings
Post by: Jim on July 12, 2003, 05:30:00 PM
91 XR2 Turbo with manual tranny. I started to hear a metal klunking when shifting but car shifted fine. Looked for the noise and if you look into the engine compartment over the engine and straight down the firewall you can see the shifting rod that attaches to the tranny. There is a joint that the rod passes through and mine no longer has the rubber? bushing and spacers. Ford/Mercury dealer tried to order but said they're NLA. Anyone had this happen and know where I can get the parts or something I can use so I won't have metal on metal.
Jim in KY
Post by: STE_6000 on July 13, 2003, 05:02:00 PM
Try looking for the part as a Mazda 323 86-89 GT or Escort Turbo 87-89.
Post by: Jim on July 14, 2003, 12:50:00 PM
I called a Ford/Mercury/Mazda dealer in Danville KY today and the parts guy helped me out with the bushing, sleeve, and spacers that are supposed to fit the shifting rod of my 91 XR2. After I get them if they don't work I'll let the list know, otherwise parts are as follows.
Description  Capri Part#  -  Mazda Part#
Sleeve       7KQ47           B09246047
Bushing      7L259           B09246047
Spacers      99952-1030      999-521-030
Post by: zxtunerdotcom on September 12, 2003, 07:45:00 PM
think you could get me some measurements?
Rod bore ID
Rod bore width
Sleeve OD
Sleeve ID
If a 1990 up protoge size is the same, i have urethane shift rod bushings for $8.99 each.
Post by: Jim on September 13, 2003, 02:13:00 PM
The Mazda Part Numbers I listed work!
Post by: Scott on November 13, 2003, 02:38:00 PM
You can also get the full set of bushings from Mid County Mustang http://www.midcomustang.com (http://www.midcomustang.com) for about $30
