April 28, 2024, 07:13:10 AM
Welcome,
Guest
Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
Home
Help
Search
Login
Register
General
General
1991 Mercury Capri questions
« previous
next »
Pages:
1
2
Print
Author
Topic: 1991 Mercury Capri questions (Read 17285 times)
kev1968
Newbie
Reply #15 on:
August 08, 2011, 03:44:00 AM »
Ok Thanks Rocket.. for the insight.. is there anything I can do to the n/t to give it any more pep
I know by adding bigger exhaust and removing the cat will increase some.. any other tricks..?
Administrator
Old-Timer
91 BPT AWD Capri & 1991 XR2
Reply #16 on:
August 08, 2011, 05:02:00 AM »
Yep, you can install a cone filter or make a cold air intake. Opening up the exhaust will help too but don't go too big with it.
I make adapters for the VAF, if you're interested:
You might be able to tweak your timing a bit too
kev1968
Newbie
Reply #17 on:
August 08, 2011, 05:13:00 AM »
Ok Rocket when I get to that point I will be sure to contact you on some of your mods you sell.. thx
Captain
Full Member
Reply #18 on:
August 08, 2011, 11:38:00 AM »
When we get more proformance by modding, does that mean, we will get less MPG or not big of a change? I sure like to boost up my n/a sometime soon. All about looks for now.
91 Mercury Capri
Capritain @ Cardomain.com
Administrator
Old-Timer
Reply #19 on:
August 08, 2011, 02:11:00 PM »
It will get less MPG if you're beating on it but *generally* you will get better mileage because you're making the engine breathe more efficiently.
When my XR2 was still 1.6 & FWD, but heavily modded, I would get up to 36mpg highway
kev1968
Newbie
Reply #20 on:
August 09, 2011, 10:21:00 AM »
Well I'm making progress I got the head off everything is looking pretty good cleaning the block up as well as the engine compartment.. Im taking the head to a buddy that is going to test it for cracks and clean it up.. Looks like I better replace the starter and alternator while im at it alot easier with the head removed.... Thanks so much for your help Rocket and everyone else that gave me advice...
Administrator
Old-Timer
Reply #21 on:
August 09, 2011, 12:27:00 PM »
The alternator can be done from the top by moving the idle valve. If you've done it before it will take less than an hour start to finish.
The starter is trickier but can still be done with a fully assembled engine
kev1968
Newbie
Reply #22 on:
August 09, 2011, 02:09:00 PM »
well things aren't looking so good I found a hair line crack near one of the head bolts... anyone have a head and dual over head cam for sale?
Administrator
Old-Timer
Reply #23 on:
August 09, 2011, 04:05:00 PM »
Ouch... Do you have a pic of it? These heads are not really known for cracking.
You can use a head from any Capri. They're all DOHC & the only difference turbo/nonturbo is the camshafts. Ask Russ if he has a head for sale
Print
Pages:
1
2
« previous
next »
General
General
