Author Topic: clutch  (Read 5325 times)
GregZ
clutch
« on: October 09, 2009, 06:11:00 PM »
I need a clutch kit that will handle closte to 200 whp and 240 ftpds or so at 16 psi with a 11/t-bird hybrid.
Will the ctock clutch be ok? or will i have to by a beefyer one? if so where do i buy it and whats it going to run me?
thanks,
Greg.
91 xr2 (SOLD)
94 Turbo\\\'d Miata (Sold)
2002 Subaru Wrx - Current DD
clutch
« Reply #1 on: October 09, 2009, 06:22:00 PM »
first and foremost.. you will not make 200whp with a t-bird turbo...or will you make 240 tq with anything less than a big 16g mitsu...
second, the stocker wont hold more than 160hp if that....
i personally run an ACT, sprung, full face disc and a centerforce 2 pressure plate...
this seems to hold my 220hp just fine...
greg, keep in mind this is a 1.6 litre engine... it will never make more TQ than horsepower...
EVER... its not possible.... to make 240 tq your talkin almost 300whp man!!!
GregZ
clutch
« Reply #2 on: October 09, 2009, 06:25:00 PM »
lol im 17 and tend to think this car is going to be alot faster than it ever will be.
thanks, Greg
91 xr2 (SOLD)
clutch
« Reply #3 on: October 09, 2009, 06:58:00 PM »
EXEDY OEM STANDARD CLUTCH KIT
Exedy Part# Make/Model Disc OD  Spline Teeth
10029
 1988 - 1989 Mazda 323 GT, GTX (1.6L Turbo) 225 mm 22
10029
 1983 - 1987 Mazda 626 / MX-6 (2.0 non-turbo) 225 mm 22
10029
 1988 - 1992 Mazda 626 / MX-6 (2.2L non-turbo) 225 mm 22
10029
 1986 - 1987 Mazda B2000 Pickup (2.0L 4cyl) 225 mm 22
10029
 1987 - 1993 Mazda B2200 Pickup (2.2L 4cyl) 225 mm 22
10029
 1988 - 1992 Ford Probe (2.2L 4cyl) 225 mm 22
 theese mazda vehicles use the same clutch...
heres a good one ..newer than mine ...really nice... at good price...
http://cgi.ebay.com/ebaymotors/Centerforce-II-Clutch-87-89-Mazda-323-CFT543007_W0QQcmdZViewItemQQhashZitem3eef687f2bQQitemZ270304575275QQptZMotorsQ5fCarQ5fTruckQ5fPartsQ5fAccessori es
clutch
« Reply #4 on: October 09, 2009, 07:13:00 PM »
icurunnin
clutch
« Reply #5 on: October 10, 2009, 04:19:00 AM »
it would be nice to find a 6 puck sprung disc for these cars but I have yet to find one.
I ran a 6 puck sprung on a stock pressure plate on my turbo saturn and loved it. you have to get use to it at first but it is streetable for daily driver use.
3 92 Galant VR-4\\\'s = sold
89 I-Mark RS = sold
91 Impulse RS = sold
3 95 TSI AWD talons = sold
93 TSI AWD talon = sold
89 Colt GT = sold
91 Capri XR2 = sold
yeah, there\\\'s more....
JackRobot
clutch
« Reply #6 on: October 10, 2009, 07:49:00 AM »
Miata clutch won't work? I found a nice stage 3 I figured they used the same clutch?
Phillip
clutch
« Reply #7 on: October 10, 2009, 09:21:00 AM »
I use a Zoom 6 puck sprung Kevlar clutch disc from an 88 RX7 non turbo. Same size and spline count as the B6t clutch. It's a bit noisy with the aluminum flywheel but it grips like a SOB.
So as a source any RX7 disc should work.
bryanknight
clutch
« Reply #8 on: October 10, 2009, 09:33:00 AM »
act has a 6 puck thats what im runnin it chaters a little with low rpm but if you just riv it up a little it goes away  Z62-HDG6 $460.00
  Heavy Duty Pressure Plate
Clamps load increase of 20% to 50%, Pedal feels stock to moderate, Many SFI Certified to insure safety
 Spring Centered (6 Pad) Disc
Recommended for Road Racing and high power Street, Increased torque capacity and spline life, Very good durability and good spline life, Quiet operation, reduced driveline shock
365 35 MZ015  6224205  RB091  PB1005 AT05
 http://www.advancedclutch.com/products/clutchkits.aspx?prod_id=6391#6391
clutch
« Reply #9 on: October 10, 2009, 10:30:00 AM »
Joe,
Tbird turbo is capable of making 200hp. Probe guys hit that mark all the time with them. I'm told it can actually support just under 300 crank HP. Also- just because those vehicles use the same clutch disk does not mean they use the same throwout and pilot bearings. Keep that in mind.
I'd recommend ACT - I'm running a Z62-HDSS (heavy duty pressure plate, super-street disk) It holds up just fine to my BPT.
The Miata clutch will work if you use a Miata flywheel - but Miata flywheels are only 200mm in diameter I think - and you'll need a MUCH stronger pressure plate to get the same hp/tq ratings.
