Author Topic: Car not running on all 4  (Read 2715 times)
oz-fire
  • TeamCapri Supporter
« on: November 15, 2014, 04:33:21 AM »
I have an N/A Capri project car, that I'm slowly restoring. My problem is that it appears to be running on only three cylinders. Today I replaced the suspect spark plug and lead, however no change. There is plenty of spark to the plug. Any suggestions , where do I look next
Re: Car not running on all 4
« Reply #1 on: November 15, 2014, 08:48:22 AM »
What makes you suspect a certain plug? Is it wetter or colored differently from the others?
Best is to perform a compression test.  You can borrow a tester from places like Autozone.
If OK compression then an injector may be malfunctioning.  Keep at it!
oz-fire
« Reply #2 on: November 16, 2014, 01:17:19 AM »
When I remove the lead from plug 4 and it makes no difference to the running engine , however when I remove a lead from plugs 1 to 3 the engine revs drop
« Reply #3 on: November 16, 2014, 09:58:50 AM »
In that case compression test is definitely the next step.  My last Capri with 0 compression had a burnt exhaust valve on #3.  That was my first engine tear-down to head removal, spent lots of hours and about $400 in head work and new valve, new gaskets, new torque wrench, and 12 point socket for head bolt removal...
« Reply #4 on: November 22, 2014, 01:31:14 PM »
Yeah, the machine shop said a couple of my exhaust valves were burnt but he was able to grind and save. It must be a common problem or results of an underlying problem. My head only cost $175 but he's an old friend of mine.
#4 is your suspect. Go to Advance or AutoZone and borrow a compression tester. With 94k my cylinders were all around 141. You'll notice a big difference on #4 from the rest.
The only other thought is to make sure #4 is firing. The easiest way is to hook a timing light to that cylinder or you can pull the plug and ground it. A cracked distributor cap can arc out a particular cylinder. Sometimes you remove the cap and watch inside it as someone cranks the motor. You'll see a blue arc as it carbon tracks. In the dark helps but you can see it in daylight. Hopefully that's your cheaper problem.
