Author Topic: Too much trans fluid  (Read 1891 times)
« on: January 11, 2019, 08:44:40 PM »
I noticed a trans leak and when I pulled the speedo drive to check it, trans fluid squirted all over the place.  Way over full.  Has anyone experienced anything like this before?
Re: Too much trans fluid
« Reply #1 on: January 12, 2019, 01:09:49 AM »
I'm guessing someone just filled it to the top? That is likely why it is leaking
There's a little diagram on the trans case next to the gear, showing the speedo gear as a dipstick.
Most autoparts stores have a big 'ol suction syringe, I think I got mine for $20, would allow you to pull out exactly the right amount of fluid
« Reply #2 on: January 12, 2019, 10:21:02 PM »
Cool, thanks.
