Author Topic: shifter  (Read 9765 times)
mitch38
shifter
« on: September 25, 2007, 10:05:00 AM »
looking for a better shifter. where can i find one?
shifter
« Reply #1 on: September 25, 2007, 10:25:00 AM »
Corksport sells a Pacesetter adjustable short-throw shifter: (scroll to the bottom)
http://corksport.com/store/category/4qcl/323-drivetrain.html
shifter
« Reply #2 on: September 25, 2007, 07:31:00 PM »
Hey Mitch! You can move the pivot ball away from the fork end of the shifter. I've done it on three of my cars. Just slice the pivot ball with a thin abrasive wheel that is available for use with a dremel tool. Afterwards wedge the ball open enough to move the ball about 1/2 inch up the shaft.release the wedge and temporarely install the shifter,check for the action. Don't go much more than this as you'll lose leverage and the mechanism will interfere with other things. When you get it right then spot weld the ball in two places keeping everything together. This a good time to replace the plastic bushings in the shifter and linkage. Good Luck Gus!
Timmygt
shifter
« Reply #3 on: January 13, 2008, 04:56:00 PM »
Quote
has anyone used this short-throw in their capri? is it the same as the mazda one?
Timmygt
shifter
« Reply #4 on: April 03, 2009, 04:51:00 AM »
do they not make short throw shifters that would work for our cars anymore?
shifter
« Reply #5 on: April 03, 2009, 06:27:00 AM »
Hey Timmy! Pull the shifter out of the car and move the pivot ball up on the shaft approx. 1/2 inch. Don't more as it won't give enough leverage and will drag on the tranny. I've done three so far.  Gus.
Phillip
shifter
« Reply #6 on: April 03, 2009, 07:25:00 AM »
Cork sport used to sell one. I bought one for my 91XR2
I went to their site and it isn't listed anymore.
Timmygt
shifter
« Reply #7 on: April 03, 2009, 01:18:00 PM »
if I move it the 1/2" will it get it out of the way of the cup holder that goes where that pocket is?
shifter
« Reply #8 on: April 03, 2009, 02:34:00 PM »
Hey Timmy!  Not entirely. Just imagine the shifter knob dropping 1/2 inch. I don't have a coin holder in my speedster so I can't tell you.  Gus
shifter
« Reply #9 on: May 30, 2009, 02:48:00 PM »
i have the adjustable unit from corksport/pacesetter... it works great and shortens throws considerably.. only issue is the shorter you go the harder it gets to shift...
but basically any adjustable throw shifter does it...its all about leverage....
http://corksport.com/86-89-mazda-323/323-interior-parts/
there ya go go get ya one ....
Heavensheros
shifter
« Reply #10 on: May 28, 2011, 01:24:00 PM »
old old thread but i just got a spare shifter and i am having troubles moving the pivot ball, suggestions?
1992 Capri XR2
RocketMan VAF adaptor
Accel wires
Irundium IX
2.5\\" Thrush exauhst
Rocket Chip
Rims
H&R Lowering Springs
Tuner FX Racing seats
Gauges w/ A-pillar gauge pods
Accel superstock coil
FMIC
shifter
« Reply #11 on: May 28, 2011, 06:09:00 PM »
did you slice it open and try to move it?
Heavensheros
shifter
« Reply #12 on: May 29, 2011, 11:11:00 AM »
doing that tomorrow !
1992 Capri XR2
Accel wires
Irundium IX
Rocket Chip
Rims
FMIC
shifter
« Reply #13 on: May 29, 2011, 12:46:00 PM »
Explains on why you could not move it...  :D
Heavensheros
shifter
« Reply #14 on: May 29, 2011, 01:24:00 PM »
well ive read where you can just heat the ball up and give it a few good wacks
1992 Capri XR2
Accel wires
Irundium IX
Rocket Chip
Rims
FMIC
