Double checked the wiring manual on Tech Capri...MIL light is indeed 1A. I can't find a circuit diagram for it though, perhaps the ECU grounds out that terminal...sounds like it.
Take a switched power wire, +12v...connect to one side of a 12v light bulb...then connect the other side of the bulb to ground...see if it flashes then
