April 28, 2024, 03:54:41 AM
Welcome,
Guest
Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
Home
Help
Search
Login
Register
Tech, Repairs, Upgrades
Capri XR-2 89-94
injectors not firing
« previous
next »
Pages: [
1
Print
Author
Topic: injectors not firing (Read 2611 times)
bhazard
Sr. Member
on:
April 05, 2010, 09:03:00 AM »
Everything's hooked up. Pressure at the rail and spark at the plugs. It just cranks and cranks. No fuel on the plugs. No power to either wire on the #4 injector plug with key on.
What's up?
Phillip
Full Member
Reply #1 on:
April 06, 2010, 07:52:00 AM »
If you crank it and put a screwdriver tip on the injector and the handle to your ear you should hear the injector firing. If it isn't getting power obviously it wont fire. here is the diagnostic for it;
http://www.techcapri.com/PDF/Repair/Capri_PCM_Fuel_Delivery_Turbocharger_S09B.pdf
Starts on 9B-38. Pretty convoluted but it's all you have.
This is the Wiring diagram, trace the power out at the ECU if you have already decided there isn't any on the injector. If there isn't power at the ECU then it's most likely dead.
http://www.techcapri.com/PDF/Repair/Capri_WIRE_91_28x17_Complete.pdf
If I remember correctly there was a problem in some of the ECU's from coolant from the heater core leaking into it and corroding a trace on the PCB. Jumping the trace with a wire repaired the problem.
Good luck, it's hard to trace electrical issues from 350 miles away. A good VOM will be your best friend on this one.
bhazard
Sr. Member
Reply #2 on:
April 06, 2010, 11:02:00 AM »
Okay upon closer inspection there's battery voltage at BOTH wires on the injector plug. I've tried swapping fuel pumps and regulators. There's definately pressure in the rail.
Phillip
Full Member
Reply #3 on:
April 06, 2010, 11:33:00 AM »
I'm not closely familiar with how the ECU works I can't find schematics for it but I would assume that the voltage is present and the ECU adds a ground to complete the circuit.
Administrator
Old-Timer
91 BPT AWD Capri & 1991 XR2
Reply #4 on:
April 06, 2010, 12:57:00 PM »
i believe thats correct.
bhazard
Sr. Member
Reply #5 on:
April 06, 2010, 02:03:00 PM »
You're gonna love this....gas lines were switched around. I'm such a stooge.
Phillip
Full Member
Reply #6 on:
April 06, 2010, 04:14:00 PM »
The screw driver thing works great you actually get to hear the injector cycling.
bhazard
Sr. Member
Reply #7 on:
April 06, 2010, 04:54:00 PM »
Yeah I was trying that too but it was too noisy under the hood, couldnt hear them.
Its running now though...
Administrator
Old-Timer
Reply #8 on:
April 06, 2010, 06:12:00 PM »
Hah, I've done that before, when I was installing my fuel cell & the walbro. I had the lines all sorts of screwed up, they switch over somewhere near the engine bay. Took a lil while for me to figure it out
Print
Pages: [
1
« previous
next »
Capri XR-2 89-94
