Author Topic: Left me stranded, wont start  (Read 2133 times)
bhazard
« on: June 02, 2010, 05:17:00 AM »
Was coming home last night from my dads, where I replaced the water pump. Its a 25 mile drive and I have about 3 miles left when it just dies... no sputtering or anything just done, as if I just turned the key off and let the engine coast down.
So Im sitting on the side of US20 at midnight with semi trucks flying by. Got my dad to come out and tow it home.
It appears to have spark.
Cam timing doesnt appear to have jumped but Im resetting it anyway just to be sure.
I got a lot of stuff wet when flushing out the cooling system and I suspected the main relay. I pulled it apart and it had nasty water in it, so I cleaned it and lubed it up with silicone spray. It appears to be functioning normally.
I also jumpered  the fuel pump on to make sure that wasnt the problem.
At this point it seems like the injectors arent firing? Theres air, and spark. I need to get some starting fluid just to make sure... if it will run on that it has to be a fueling issue.
bhazard
« Reply #1 on: June 02, 2010, 06:25:00 AM »
Its gotta be a fueling issue, it runs when I put gas in the intake. What would cause the injectors to not fire?
bhazard
« Reply #2 on: June 02, 2010, 08:09:00 AM »
Okay theres no 12v going to the injectors with key on, HMMMM
bhazard
« Reply #3 on: June 02, 2010, 09:05:00 AM »
Nevermind, it is in fact the main relay. Strange thing is, one side is all old and corroded looking and the other side is nice and clean, and its the clean side that isnt 'clicking' on!
« Reply #4 on: June 02, 2010, 04:35:00 PM »
First thought was the belt...
second the reset switch in the trunk for the fuel
but water does odd things to electronics thats for sure
