Author Topic: fuel pump wiring  (Read 1867 times)
Heavensheros
fuel pump wiring
« on: August 23, 2010, 03:34:00 AM »
so i had to move my battery from my back seat area to the trunk. after doing this now for some reason my stock fuel pump wire has no power to the relay. if i touch 12v wire to the relay it switches on and if i touch the 12v power to the pump wire it works but the stock switched 12v power source going to the relay does not work anymore after moving my batter.... nothing about the fuel pump wire changed accept the main 12v power going from battery to relay. what happened ?
1992 Capri XR2
RocketMan VAF adaptor
Accel wires
Irundium IX
2.5\\" Thrush exauhst
Rocket Chip
Rims
H&R Lowering Springs
Tuner FX Racing seats
Gauges w/ A-pillar gauge pods
Accel superstock coil
FMIC
fuel pump wiring
« Reply #1 on: August 23, 2010, 06:01:00 PM »
Did you trip the rollover switch in the trunk?
