yeah changed it already.
thank you all for your post
so yesterday i decided to ground the STI connector again to see if it would give my any codes and this time it did it gave me codes 01 and 08.
01= ignition diagnostic monitor(IDM)
08= volume air flow (VAF) meter
so im guessing my guess was right it was the vaf meter so i inspected it closely and after that i decided to give it a few mechanic adjustments. i gave it a few light hits with a hammer and then with my fingers wipe the sensor located in the inlet and for my luck its turn on and stayed on
i drove it a few times around the block with no noticeable hesitations or loss of power yay!!
so it was probably the way i had my intake config,(with the sensor pointing straight down) which is weird since it had already been like that for like 3 mths or maybe just dust in the sensor chamber im going to buy some mass sensor cleaner and after that hope thats thats for that problem
thanks again everyone!!!
now about code 01 any better description, would it have given it to me because of the same problem with the meter
