General => General => Topic started by: ShaneOss on March 17, 2014, 05:43:32 PM
Hi,
Wondering if anyone had an adx or xdf file for the Capri for use in TunerPro?
Was hoping to look at hooking up a OBD1 to Bluetooth interface to the Capri for some realtime data logging. :)
I've got ScanXL Pro which works great on my Mazda 6 with OBD2 but no good for OBD1. :(
Cheers.
I'm not sure that our cars are even OBD1 compliant, no datastream. We have a MECS ECU. You'd have to manually log each sensor on it's own channel. I used Megasquirt for this back in the day.
MECs hasn't really been mapped. You could try running a Honda ECU with hondata or similar, that's been done before. Megasquirt that fits into the stock ECU case would be your best bet for tuning, get rid of the junk distributor and VAF while you're at it
Thanks for the info. I see what you mean now.
Megasquirt looks interesting. :D
I might be back to you soon for a rocketchip too. I just scored an XR2 94 SE as a donor car for my 92 SC Clubsprint. So now I've got a spare ECU I could post over.
