Author Topic: cooling fan  (Read 2988 times)
Piojo
cooling fan
« on: December 07, 2011, 11:15:00 AM »
my cooling fan turn on and stays on after I set the switch in start before turning the engine on. after i turn the engine on the fan keeps spinning. i know this isnt normal. what can be the problem here?
cooling fan
« Reply #1 on: December 07, 2011, 12:34:00 PM »
Broken wire on the thermostat housing sensor.
Piojo
cooling fan
« Reply #2 on: December 07, 2011, 01:06:00 PM »
where is the thermostat housing sensor located
cooling fan
« Reply #3 on: December 07, 2011, 02:39:00 PM »
It's in the thermostat housing, it's a single blade style connector. Follow the radiator hose to where it meets the head, you'll find it.
