Author Topic: Stock boost gauge prob  (Read 1761 times)
xfwrxreaper
« on: May 30, 2010, 08:53:00 AM »
Okay, so about a week ago I took my hard top off and put the soft top up. well when I put the soft top down the next day the soft top caught the dome light pig tail and crushed it. 1 day later the clock went out but backlight still works, then the reading lamps went out...and now 2 week later the boost gauge is acting really funny. when I turn the ignition on the boost gauge goes to 6 psi and when i start car and rev it it goes up to 1 inch back 15psi. its acting like its a TPS. more throttle i apply the higher the boost gauge goes. the car seems to run fine but does anyone have a clue about what this could be.
sorry about the wall of text.
« Reply #1 on: May 30, 2010, 09:31:00 AM »
that pigtail is also for the defrost...that goes to the dash. check and make sure that you do not have wires shorting out where it got caught..
