Pages: 1 2 [3]
Author Topic: Headlight Troubleshooting - any further tips?  (Read 5160 times)
Re: Headlight Troubleshooting - any further tips?
« Reply #30 on: October 29, 2022, 06:50:19 AM »
Easy first step for turn signals is to use a battery brush on the sockets and a little grease. Of course, all seven, I think, grounds in the engine compartment need to be cleaned and greased.
See, I'm a jerk and left both my multi-meter and power-probe at work, an hour away, last night. Now I get to spend all weekend on my car with the mystery electrical issue, with no diagnostic tools. But thanks Wolf, I do believe I have a tube of di-electric grease, a wire brush, and an angle grinder. At least I can rule out a silly ground issue.
In fact, maybe I'll go a bit wild with it. I can run a big fat ground from where I grounded the battery to the chassis, to the block and to the head. Then I can collect those (4 or 5, I think) little grounds all around the battery tray, and thermostat housing and run them right to the big lug I installed. I think there is one last little ground over by the FR headlamp/PS pump, I'd probably run that little guy over there too. Then I can check all of my engine grounds in one spot!
GermanXR2
    • XR2 Turbo
« Reply #31 on: October 30, 2022, 07:07:12 AM »
I had the same problem and was surprised how rusty the bulb holder was.
I wrapped a thick pencil with sand paper and then removed the rust from the inside of the bulb holder. To protect i use contact spray. Then I installed the bulb and the loose contact was still there. I use a spark plug pliers and reduced the diameter of the bulb holder. Now it works again.
The gasket around the light is dry, any possible replacement ideas?
« Reply #32 on: October 30, 2022, 06:37:30 PM »
Do they sell the big boxes with the multiple sizes of O-rings in them where you are? Maybe you'll get lucky and that'll have the right size. Otherwise, you could try and re-condition the original seal with silicone spray
Pages: 1 2 [3]
