Greets.
I'm the proud owner of a 93 Capri N/A. I have always wanted to be a car guy and have a car to work on. Long story short, I ended up choosing a 93 Capri with 65k miles on it. I've really enjoyed it so far. I got a pretty good deal on it and I've already had some fun diagnosing issues. Proudest moment so far, being that I managed to hunt down a bad electrical connection which caused the car to fail to start every now and again.
I thought I had a totally rust free car, but I found a patch of frame rot. On the passenger side, a little bit behind the front wheel, on the rail, there was a rust spot. Through the sheet metal that covers the rail and rust on the rail itself. See image here:
I'm a bit new to this jazz, but my basic understanding of how to tackle this is to clean the rust, seal/neutralize, prime over and keep an eye on it. As you may be able to tell by the picture, I've been working on just that.
Problem is this: The rail is behind a piece of sheet metal. I want to make sure I get all of the rust on the rail, so, I've pulled back a bit of the sheet metal. However, even after pulling back some of the sheet, i'm still finding more rust at the edges. (If I put a screwdriver around the edges, I still get dusty crackly rust/scale behind the sheet.)
I realize that perhaps I'm approaching this wrong. Rather than tear up the sheet metal bit by bit, is there a way to get the sheet metal cover off the rail so I can get at it better in order to clean it up better? Or anybody have any other ideas?
Thanks!
