Tech, Repairs, Upgrades => Brakes/Suspension/Tires/Wheels => Topic started by: sterling94capri on August 11, 2011, 03:56:00 AM
Got the Energy Suspension end links in.Had to go get shorter hardened steel bolts. It is a tight fit,I hope we put them in right! Sounds a lot better than clunk-clunk though.Rocky
did these part numbers ever get posted? I need to do this in the front.
also, was the bolt that came with too long? where did you get the other one and what size was it?
do you have pics of the parts?
JJ,mine were rear links. The part # is 9.8125R. But the bolts and sleeves were to long so they had to be cut down. If you are going to be at the MACG you can see the shinny red bushings in person!Rocky
I also was looking for the rear energy suspension but didn't know which one to get.now does anyone know the size for the center rear swaybar bushings for the n/a
