Does your car have A/C? Do both belts fail, or just the accesory drive(front) belt?
If it doesn't have A/C, and it's just the frontal belt I'd suspect the idler has seized up, which should be checked everytime you change belts. If that's not the case, you might be overtightening/overloosening your belt tension on one or both belts.
Holy geeze, of all people you should know this:
1. All US destined Capris were equipped with AC.
2. The capri does not use an idler for ANY accessory drive belt. If you have deleted AC, you run a smaller belt driving only the PS pump.
3.Alt/WP belt failure is documented in a recall/TSB:
92B09 OCT 92 Campaign - Alternator Pulley and Belt ReplacementThe pulley is not correct for the alternator, or is misaligned. Do you have the pulley from your old alternator? Also try this belt, it has been recommended on the Yahoo! group (it's a heavy duty lawn mower belt from NAPA) HEAVY DUTY FHP BELT #4L360W
