Author Topic: MX3 Engine?  (Read 4578 times)
MX3 Engine?
« on: December 29, 2009, 11:59:00 AM »
According to what i found..the NA B6 is the same in the MX-3 can anyone confirm this?
MX3 Engine?
« Reply #1 on: December 29, 2009, 03:15:00 PM »
I'm not sure. I know certain years may have got a B6 with a totally re-designed head
MX3 Engine?
« Reply #2 on: December 29, 2009, 03:19:00 PM »
B6
1,597 cc (1.597 L; 97.5 cu in) B6 — (78x83.6 mm) — This was a bored-out version of the B3. The 8-valve SOHC B6 was found in the 1985-1989 Mazda 323, the 1988-1990 Mercury Tracer, and the 1990-1994 Mazda 323, and the 1992 Mazda MX-3. The B6 was also found in the 1993-1998 kia sephia and produced 82 hp (61 kW).
In Japan and Australia a fuel-injected version called the B6F was available.
[edit] B6-2E
1,597 cc (1.597 L; 97.5 cu in) B6-2E - (78x83.6 mm), also known as B6-ME - This was a variant of the B6-E with a 16-valve cylinder head. It is found in the 1991-1994 Mercury Capri, 1992-1994 California-spec Mazda 323 and 1992-1993 Mazda MX-3. The B6-ME produced 88 hp (66 kW) and 96 ft·lbf (130 N·m).
[edit] B6T
1,597 cc (1.597 L; 97.5 cu in) B6T - (78x83.6 mm) - The ubiquitous turbocharged, fuel-injected and intercooled 16-valve DOHC B6, released in 1985 and used in numerous models worldwide including the 323 GT-X, 1985-1989 Mazda Familia GT-X/GT, 1985-1989 Ford Laser TX3 turbo, and later Mercury Capri's. This engine was most commonly found mated to a 4WD drivetrain although FWD models were also available in the capri XR2 & 323 GT.
Power and torque outputs varied across markets due to emission and fuel standards.
The B6T available in north america came with 132 HP & 136 ft-lbs
The Japanese version of the B6T was the most powerful, producing 147 hp (110 kW) and 137 ft·lbf (186 N·m) due to better intake manifold & ecu tuning for better gasoline 95 octane
from wikipedia..so its why i am wondering. a guy with a MX 3 was wanting to maybe buy the one i have here
http://en.wikipedia.org/wiki/Mazda_B_engine
MX3 Engine?
« Reply #3 on: January 01, 2010, 06:21:00 AM »
MX3 Engine?
« Reply #4 on: January 01, 2010, 06:37:00 AM »
MX3 Engine?
« Reply #5 on: January 01, 2010, 06:45:00 AM »
intake mani is different .. valvecover is different.. distributor runs off the exhaust cam... computer is totally different and id imagine the harness is quite different...
first gen 4 cyl mx3s came with the SOHC B6 (middle picture)
the 2nd gen or 93 1/2 up came with the new version DOHC B6 (first and third pics)... unfortunately mazda made so many changes, its hard to use more than just the block and internals... its a b6, but like the miata this was definately a different version using the same block....
MX3 Engine?
« Reply #6 on: January 01, 2010, 04:44:00 PM »
Pretty sure the heads are different, but can be swapped, because the intake manifold is not compatible with our heads.
Point being if he swapped everything in total it'd probably work, but not bits 'n pieces.
MX3 Engine?
« Reply #7 on: January 01, 2010, 10:32:00 PM »
10-4  good buddy.... he might need a computer and harness to get it to work...
but the swap should be easy.. since your bolting the mx3 mounts to a b6 block ...
and yes tell him a b6t in an mx3 with mild mods will crush a v-6 mx3...and then some....
the next task sounds to me to be driveline, what tranny to use ???
MX3 Engine?
« Reply #8 on: January 02, 2010, 01:39:00 AM »
i am selling a na motor....he wanted to know if it would be the same
MX3 Engine?
« Reply #9 on: January 02, 2010, 08:30:00 AM »
different head, sensors, and computer system ... he can use the shortblock only.....
