Author Topic: IGNITER  (Read 5784 times)
vintage5
IGNITER
« on: September 11, 2011, 07:29:00 AM »
Where can I purchase a Igniter?
Chicken
IGNITER
« Reply #1 on: September 11, 2011, 08:52:00 AM »
The Ignition Coil at the Air Box??
WIDELY available.
vintage5
IGNITER
« Reply #2 on: September 11, 2011, 09:55:00 AM »
No. Inside the distributor.
IGNITER
« Reply #3 on: September 11, 2011, 10:32:00 AM »
I started a part number master list:
http://www.werbatfik.com/partnumbers.htm
Try searching eBay for the Mitsubishi part numbers, I have found them as cheap as $35 before
vintage5
IGNITER
« Reply #4 on: September 11, 2011, 12:48:00 PM »
Thanks again Rocketman. It may not be the igniter. The firing looks good BUT when I try to push the gas pedal setting still the engine goes dead as if it was starving for gas?
IGNITER
« Reply #5 on: September 11, 2011, 03:25:00 PM »
If the car runs fine otherwise, or runs fine (or at least idles) once warm it's not the ignitor. They either work or do not work, sometimes intermittent but temperature related & progressively worse (fail as the engine warms up)
The symptoms you describe sound like a bad vacuum leak somewhere behind the VAF
vintage5
IGNITER
« Reply #6 on: September 11, 2011, 05:50:00 PM »
This all started when I was cleaning the ground terminals on the passenger side and drivers side, I also checked the plugs around and under the air box and coolent tank.
vintage5
IGNITER
« Reply #7 on: September 13, 2011, 04:35:00 PM »
I have fire but no start. I have gas at the fuel rail.
IGNITER
« Reply #8 on: September 13, 2011, 04:45:00 PM »
Did you clean the ground near the thermostat housing? Does your tachometer show any RPM's (200-300)when cranking?
vintage5
IGNITER
« Reply #9 on: September 13, 2011, 05:05:00 PM »
The tech does move to 200 to 300 rpm. and it tries to crank when I first hit the starter but don't. It was running ok before it cleaned the grounds and checked the plug in terminals. The motor had gotten a little lazy.
IGNITER
« Reply #10 on: September 13, 2011, 05:13:00 PM »
Hmmmm that's a tough one. Did you mess with the fuel injector harness plug? If that isn't seated correctly the injectors won't get a signal.
Have you tried using starting fluid?
vintage5
IGNITER
« Reply #11 on: September 13, 2011, 05:31:00 PM »
When I first got thru cleaning the grounds it would crank but when I tried to rev up the motor it would go dead or die down until I backed off then it would idle but now it want crank at all. Just like it was sarving for gas.
vintage5
IGNITER
« Reply #12 on: September 13, 2011, 05:38:00 PM »
What kind of voltage should I read at the injectors and when?
Chicken
IGNITER
« Reply #13 on: September 14, 2011, 12:08:00 PM »
vintage5
Member # 4113
  posted September 11, 2011 11:50 PM
Please describe "checked".
If you touched any Air Intake stuff, check for cracks, loose, leaks
vintage5
IGNITER
« Reply #14 on: September 14, 2011, 03:42:00 PM »
All I did with the connections was to unplug them and clean the terminals.
