April 28, 2024, 03:56:53 PM
Welcome,
Guest
Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
Home
Help
Search
Login
Register
Tech, Repairs, Upgrades
Capri XR-2 89-94
code 88
« previous
next »
Pages: [
1
Print
Author
Topic: code 88 (Read 2874 times)
Xr2oldman
Newbie
86 GLHS
code 88
on:
May 27, 2016, 06:59:46 PM »
where is the variable voltage choke relay? The car starts and purrs for about ten seconds then starts to run bad and seems to flood out and die. cant find this info anywhere. i thought i could find it easy but i cant find anything using the search bar on here.
Xr2oldman
Newbie
86 GLHS
Re: code 88
Reply #1 on:
May 28, 2016, 08:38:23 AM »
The car doesn't die now. Took it up and down the street a few times to see if it cleared up but it is missing really bad and seems like its flooded. Did some poking around under the hood and i think i know what everything is but the vvc. Im starting to think that its apart of something else. For example the vvc might be inside the idle control motor. Or maybe it is a ford terminology that im not familiar with and the vvc is the idle control.
Xr2oldman
Newbie
86 GLHS
Re: code 88
Reply #2 on:
May 28, 2016, 08:56:19 AM »
code 88 also says Ignition Diagnostic Monitor/Dual Plug Ignition or spout circuit fault - Ignition Systems. It could be a ignition timing issue. If the timing was off then i could see this being the problem. It purrs at idle but you cant drive it. Also i noticed once it was up to temp that the exhaust smelled ok.(not to rich)
How does a 91 xr2 know engine position for spark timing?
Last Edit: May 28, 2016, 09:03:59 AM by Xr2oldman
NomakeWan
Full Member
93 Capri XR2
Re: code 88
Reply #3 on:
May 28, 2016, 04:02:20 PM »
Spark timing is adjusted by moving the distributor one way or the other. You'll want a timing light to check the marks on the crank pulley for this. You'll also want to note that if your harmonic balancer is bad, then your timing will seem to 'drift' even though that's impossible when looking at the marks with a timing light. Us Californians with our smog checks have a real problem with that as the tech will fail you for improper timing even if the timing is correct.
Sr. Member
91 BP Capri GT
Re: code 88
Reply #4 on:
May 28, 2016, 04:57:39 PM »
The Capri doesn’t have VVC and our cars use OBD 1, so there’s no code 88.
You might have a code 8, which is a VAF Signal issue.
I would try undoing and cleaning the electrical connector going to the VAF locate on top of the airbox.
Xr2oldman
Newbie
86 GLHS
Re: code 88
Reply #5 on:
May 28, 2016, 06:49:54 PM »
thanks. The plug has been messed with before. Looks like the unit has been removed from the airbox and rtv was used to hold it in. i hope a good cleaning will do. might have to replace it
Sr. Member
91 XR2
Re: code 88
Reply #6 on:
May 30, 2016, 02:07:37 PM »
Do be careful with the MAF sensor. They make a special cleaner for that. There are certain metals used in those and coatings, so you can't just scrub those with Gunk Engine Brite. You can look up more advice online on how to clean an MAF.
Xr2oldman
Newbie
86 GLHS
Re: code 88
Reply #7 on:
May 30, 2016, 07:18:16 PM »
I found that the wires inside the VAF were broken and only touching for contact. Someone had taken the two screws out from the plug and yanked the plug free from the circuit board. idiots
It was probably done during an air cleaner change. Who knows the history of this poor car but i got what was left soldered back to the board. 2 of the three wires are like new but that third one needed improvising.
Print
Pages: [
1
« previous
next »
Capri XR-2 89-94
code 88
