A guy named 'Steve' has just posted a file on Air Bags in 'capriamerica'(yahoo). He has said if cruise control and/or other steering columns fuctions are working, then the 'clockspring' should be ok. Further, he describes that our Air Bag module are hung in a vertigo position and therefore leaks from componets within the module units could give out several codes. Luckily for us, our module on the 91-94 are the same as Ford tarus's and other Ford models from early 90s. (maybe over 300000 available in junk yards). I plan to go to my nearest 'pick a part' today or tomorrow. 'Steve' describes the location and replacement in capris can be differcult. I dont understand if module is under/behind fuse box or the fuse box must be loosened and the wire harness remove (to gain access to module). This is the last thing I need to fix on my Capri, for it to be perfect. thank you for reading
