When I bought the car, the PO said it had a heating problem. When I got it started, a belt was screaming. I discovered the bracket wasn't bolted to the block. Solved the screaming problem. The first time I took it out, after a couple of miles the temp started going up. It got almost into the red. When I stopped, it was filling the overflow and the fan hadn't turned on. I found the fan was disconnected, connected it, turned on the ignition, fan came on, problem solved.....WRONG!!!!! Fired it up today, belt screaming. Drove it a couple of miles, belt quieted after about a half a mile because it had jumped off. Temp ran up almost as high as yesterday, but no boiling, also no fan. Turned off to check belt, turned it back on, fan ran. Getting a new belt tomorrow. I did a search and will check the damper tomorrow. Also found the location of the fan temp switch and relay, am wondering where the gauge sensor is located, maybe it isn't getting as hot as indicated?
Thanks any help you can give, Jack Byrd
