Author Topic: Hardtop install  (Read 11921 times)
Snigalfriz
    • 1991 NA Capri
Hardtop install
« Reply #15 on: November 16, 2011, 03:27:00 AM »
I see the two bolt above the visor.
1991 Mercury Capri 5-sp
1992 Mercury Capri 5-sp swap
1999 Ford Contour SE 24v v6
2003 Lincoln LS
2007 Saturn Outlook XE AWD
2014 Chevy Cruze LT
Hardtop install
« Reply #16 on: November 16, 2011, 06:15:00 PM »
The bolts above the visor are the same thread pitch as the rear bolts, just different styles...
I've posted a picture of the rear bolts on yahoo capri group, in photos, 'hardtops' I believe.
For 15 minutes work I made my rear bolts with no waiting for the mail and for someone else to decide to send them to me.
Of course, for the mechanically challenged, lazy, or busy folks, mail order is always there...as I suspect we will be reminded of many times in the near future...
Chris
Hardtop install
« Reply #17 on: November 16, 2011, 06:49:00 PM »
I wish I could figure out how to remove my middle rear bolt, it won't line up properly or sit flush to allow me to put the cap over it.
Hardtop install
« Reply #18 on: November 17, 2011, 03:23:00 AM »
All my tops are on cars right now, but one of them acts like yours, the middle bolt doesn't go down far enough...I think the threaded insert in the top has probably rotated around, leaving it too high...so when the rear bolt is installed it is too high also...next time the top is off (mine too!) look at that insert to see if you can put it down farther, back into place...share pics if you do it soon...Chris
Snigalfriz
    • 1991 NA Capri
Hardtop install
« Reply #19 on: November 21, 2011, 05:41:00 AM »
Picked up the top and installed it. It was very easy, thanks for everyone's input.  I am missing the bolt behind the passenger seat, but I am replacing it.
Does anyone have a rear defroster switch?
2003 Lincoln LS
2014 Chevy Cruze LT
Hardtop install
« Reply #20 on: November 21, 2011, 09:08:00 AM »
Besides the switch, you need the relay, as well!!
 Roo-Sport.com  or (503)9194 CAPri!!
Snigalfriz
    • 1991 NA Capri
Hardtop install
« Reply #21 on: November 22, 2011, 07:09:00 AM »
Where in the trunk is the relay location?
2003 Lincoln LS
2014 Chevy Cruze LT
Hardtop install
« Reply #22 on: November 22, 2011, 07:59:00 AM »
Under the trunk floor, right next to the emergency fuel cutoff switch. The relay actually bolts to the cut off switches bracket.....
Snigalfriz
    • 1991 NA Capri
Hardtop install
« Reply #23 on: December 18, 2011, 07:56:00 AM »
Both sides are leaking at the joint of the small front window.  Any ideas on a fix or adjustments on installing?
2003 Lincoln LS
2014 Chevy Cruze LT
