Author Topic: Mazda na nb crome alloy flywheel ?  (Read 2839 times)
DarkAngel
    • Build Thread
Current Project XR2 SE
To Do
tracker gps, respray
Re: Mazda na nb crome alloy flywheel ?
« Reply #1 on: February 15, 2017, 10:53:06 AM »
Can't help you, but had to say that's really cool.
rsharry
    • Capri and Capri XR2
« Reply #2 on: February 15, 2017, 01:50:14 PM »
Would be very interesting to know if it works. The flywheel will fit to the crankshaft but dont know if it  has the correct dimension to use it with the capri gearbox
« Reply #3 on: February 15, 2017, 07:10:06 PM »
Just get the findaza flywheel made for the motor. No guessing.
DarkAngel
    • Build Thread
« Reply #4 on: February 15, 2017, 07:27:10 PM »
Saving about $200 AUD is tempting IF this part fits the capri 5 speed transmission.
To Do
« Reply #5 on: February 15, 2017, 07:33:54 PM »
Im thinking it should work, because I ended up  using a Miata clutch on my Capri.
« Reply #6 on: February 15, 2017, 11:39:42 PM »
It will not direct fit the XR2
You can make a clutch combo that will work, but you have to use a smaller clutch disk size. (miata uses smaller disk) The ONE thing the XR2 transmission has going for it is a large clutch disk
AZGTX is right, get the proper Fidanza flywheel - if you shop around or buy used you can get a deal. I have one in the GTXR2 and one in my red XR2, with a ACT clutch - bulletproof combo.
Personally I kinda prefer the stock flywheel - don't notice much gains from the lighter weight, and makes it tougher to drive especially with a grabby clutch. I only threw it in the red XR2 because I didn't have a good stock flywheel, I was in a pinch - and I had the Fidanza bit on the shelf ready to go
