Author Topic: Water hose ID  (Read 2272 times)
1991MCapri
    • Capri
Water hose ID
« on: November 07, 2016, 05:19:07 PM »
Hi, My son's '91 Capri has an antifreeze leak that appears to be coming from under and slightly behind the idle speed control valve above the alternator. I can see a small diameter hose there using a mirror that is leaking. My question is does anyone know the name of this hose so that I can go to the parts store and get a replacement. It appears to connect to the bottom of the idle speed control valve I believe and then into the head. The hose does appear to be a preformed one so I searched online but have not been able to find one, as I don't know what it is called. Any help would be greatly appreciated.
Jim
1991MCapri
    • Capri
Re: Water hose ID
« Reply #1 on: November 08, 2016, 03:21:52 PM »
Disregard, I found the hose. Repair completed.
