Ok, I have watched what is going on ad I'll get the puff of smoke if I get into boost. I believe it drinks at least a half-pint when this happens! She still runs fine, but this has got to end soon. I've been staying out of the throttle just to keep things safe, and it has been working, I hardly drop in 1000 mi if I keep my foot out of it. That bonus benefit is I have gotten the best milage I've ever seen since I sold my 86 Escort GT, 32 MPG!
Well, I picked up a used vj11 with 0 shaft play - it's not cleaned up, but it seems good. I'll have to get some more parts I think. I just got the exhaust manifold gaskets (2 for some reason), and the turbo flange gasket set. I wonder if "clocking" or positioning the vj11 on the vj14 exhaust housing requires more gaskets? I see a round flange with bolts that hold the cartridge section to the turbine and impeller housings. Can the round cartridge flange just be loosened and turned as needed to help with coolant and oil line fitment (line up)?
I also see that the coolant ports have what some call Banjo bolts connecting the tubes to the housing. Can these be loosened and turned some? If so, where do I get the gaskets, seals?
I'm going to try to post some pictures of the vj11, and maybe start a thread documenting the hybrid build. I will have questions about good recommendations for high flow catalysts, and complete induction kits with better intercoolers. I already have a 2-1/2" exhaust, but still have the small downpipe and original cat. Might be time to go bigger flow.
