Author Topic: rear brake  (Read 4747 times)
Capritain
rear brake
« on: September 29, 2015, 12:29:02 AM »
Haven't drive my car for years. Drove it out the drive way today and only got little grip. Took a look noticed its smaller than the front and the pad is drown in the disc.
Thinking of replacing both rotor and pads. Anything I should watch out for working on them? Are they same as the front?
91 CAPRAI N/A 5-Speed
D-town, Iowa
Re: rear brake
« Reply #1 on: September 29, 2015, 11:39:28 AM »
The rears are different from the front.  There are apparently two different sizes of rear pads.  One looks like go kart pads.  Not the ones I had.  I had to hammer the old ones off and also hammer the new ones on.  They seem to work okay although the e-brake doesn't work as well.  I've considered taking it down and filing on the pads a little to see if the clearance helps any.
Capritain
Re: rear brake
« Reply #2 on: September 29, 2015, 01:59:46 PM »
what about the disc, is it hard to replace as the front?
D-town, Iowa
Re: rear brake
« Reply #3 on: September 29, 2015, 08:06:34 PM »
Rear rotors are easy, unstake and remove the nut, remove the brake caliper, and off it comes.
Re: rear brake
« Reply #4 on: September 29, 2015, 08:10:08 PM »
Nah, it's not as bad as the front. You'll need new spindle nuts and if the wheel bearings haven't been touched in a long time then now is a good time to replace them. Make sure you pack them good with grease and use a new wheel seal with your new rotor. Grease the lip of the seal. Also with the brakes clean and grease the slides for smooth operation.
You'll see 4 mount bolts, two are for the emergency brake assembly. There is no need removing them, just the two for the caliper.
You can go to techcapri and download group 12 brakes for illustrations and instructions including the spindle nut torque.
Re: rear brake
« Reply #5 on: September 29, 2015, 08:11:02 PM »
« Last Edit: September 29, 2015, 08:14:18 PM by mitch1204 »
Re: rear brake
« Reply #6 on: September 30, 2015, 09:59:19 AM »
I had to remove the e-brake bracket to get the caliper bolt out.
Jack
Re: rear brake
« Reply #7 on: September 30, 2015, 07:18:57 PM »
Quote
Jack
Maybe so, lol. The memory is going. I remember taking it all off and saying that was a wasted step. Maybe because I took it all apart I didn't see that. :)
I got new brakes. I'll find out in a few years, lol.
