Author Topic: HOW TO - Get better sound quality and life out of your door speakers  (Read 5034 times)
Heavensheros
ok im sure as us capri owners have noticed that our doors arent as water tight as they should be, i have noticed down the years of owning mine i have a speaker maginet rust and come loose from the basket, and i have had adaptor rings get wet like this one
this can be a problem because it can damage your speakers and give you poor sound quality,
i noticed that our doors make very poor enclosures for 5 1/4 even 6 1/2" speakers
Another thing i came to notice is that our doors in the stock location only have about 2 1/4 inch of space untill you hit that brace so for any good upgrade of speakers you really have to make some kind of riser for them, so lets start with that,
use MDF or Birch 1/2" or 3/4" thick and make a speaker ring and screw it down to the stock location
next if you have a problem with water you dont want that ring getting wet, i used shurtape AF100 foil tape and surounded the ring to seal it from the elements and also add some strength so it does not split
now a good thing to do is seal the speaker off from the elements and give the speaker a smaller enclosure to produce better sound quality is use a baffle, what i used was DEI Boom Mat and i then put it into the speaker ring
you will need to poke a small hole into the baffle for the speaker wire and using some tape seal the hole up.
Finally screw down your speaker and put the door back together and start jamming out to some loud music with AMAZING sound quality and AMAZING bass response !!
1992 Capri XR2
RocketMan VAF adaptor
Accel wires
Irundium IX
2.5\\" Thrush exauhst
Rocket Chip
Rims
H&R Lowering Springs
Tuner FX Racing seats
Gauges w/ A-pillar gauge pods
Accel superstock coil
FMIC
« Reply #1 on: April 29, 2011, 03:05:00 PM »
For best sound quality, do I have to paint everything red? I understand that red paint reflects the sound the best. Is this correct?
Heavensheros
« Reply #2 on: April 29, 2011, 03:46:00 PM »
i see what you did there......
1992 Capri XR2
Accel wires
Irundium IX
Rocket Chip
Rims
FMIC
« Reply #3 on: April 29, 2011, 03:57:00 PM »
Red paint's pigment has the highest molecular density, making it the best paint for obtaining the highest fidelity sound.
/lol.
Heavensheros
« Reply #4 on: April 29, 2011, 05:33:00 PM »
i try to post a helpful post and this is the thanks i get, you guys better be glad i see team capri as a big family !!!
1992 Capri XR2
Accel wires
Irundium IX
Rocket Chip
Rims
FMIC
« Reply #5 on: April 29, 2011, 06:48:00 PM »
If this is one big family, are you the RED headed step child??
Heavensheros
« Reply #6 on: April 30, 2011, 06:07:00 PM »
yes!
1992 Capri XR2
Accel wires
Irundium IX
Rocket Chip
Rims
FMIC
Colorado1
« Reply #7 on: April 30, 2011, 11:23:00 PM »
I don't even have a radio yet! There's one in there but no face plate when I bought it. There is a red constant blinking light so it's my fake alarm system!
kelly270
    • http://na
« Reply #8 on: May 23, 2011, 07:39:00 PM »
yeah josh-thats good shit!!! I cant wat to pull my 285 watt alpines out and try it!! I am in the proccess of building a box for where the back seat went and have a decent 800 watt amp, i will have to replace the bitchin' explodes in the back, any one got some dynoite so the can really explode!!! good thread josh-dont let these fellows give you no shit.
92 XR2
soon to have a new heart
« Reply #9 on: May 23, 2011, 07:56:00 PM »
I had the opportunity to enjoy the sound system in person, it hits hard as hell & has incredible clarity. Sure, it's red overload but it sounds awesome ;P
« Reply #10 on: May 24, 2011, 05:22:00 AM »
Well it has been proven that for each red part painted you get 5DB more just like in the Honda world you get 5HP for every sticker or JDM items installed....
There is also a plastic cover that you can pick up that will protect it the best. it will repel the water. then use the matting inside the cover. i picked up my cover at autozone. i have seen several cars use them as well stock so can be found in the yards as well
