Author Topic: ECT RE-WIRING  (Read 2258 times)
mcanchola2
ECT RE-WIRING
« on: April 01, 2014, 07:31:28 PM »
can someone help me pin point the two wire that go to the engine coolant temp sensor. what color are they coming out of the ECU yellow connectors. the check engine light give me that code. i already changed the sensor but it still gives me that same code. yes i have reset the codes and it still give me that one..and i was thinking since the car is old maybe somewhere in the wiring the wires must of riped or something...what i wanted to do was to cut the two wires coming out of the ECU and installing new wiring and run it all the way to the ETC and hopefully that will solve the problem.
