In an attempt to keep from receiving an involuntary enema from a mechanic, who is inspecting my 91 xr2 (build date 5/91) to pass smog, I will pass along the story to become more educated.
1. First smog test: timing was said to be 22 degrees btdc, passed emissions
2. My mechanic said was 10 btdc
3. second smog: (same company, diff location, diff tech) timing 8 atdc
4. to diff mech, does smog inspection: set timing at 12 btdc, old dude try to sell me harmonic balancer
5. back to first smog tester: timing read 15 btdc (passed, 3 degree viarance), failed the CO by a hair.
6. back to smog inspection mechanic- pulled #1 plug, found tdc, said harmonic balancer moves, so cannot read timing. said there is some "rubber" in the balancer which moves. Need replace harmonic balancer.
Could this be true? Even if the car runs good, idles good, cranks good, and seems to be correct timing, does the balancer need to be replaced?
He also mentioned the Vibration Damper.
this will be part of the Capri library which you smart guys built.
Am going to look up in my shop manual to see what it looks like, but need the feedback from guys who are not interested in hosing me.
