Pages: [1] 2 3
Author Topic: poping sound  (Read 9827 times)
twistedhhhdx625
  • Guest
poping sound
« on: October 11, 2004, 06:57:00 PM »
every time i stop i hear a popping sound from the front passanger side and i think its either a shock or a strut...my suspension is crap anyways and im planning on redoing the whole thing but i just want to know if its damaging to anything else.
eric
poping sound
« Reply #1 on: October 12, 2004, 02:14:00 PM »
The popping sound you hear is your mechanics heels as he prepares to do you in. But really, chances are you have a bad strut and it is causing your CV joint to flex. Either way, the mechanic gets happy.
capri303
poping sound
« Reply #2 on: October 12, 2004, 03:42:00 PM »
I hear the same sound and have been since I've owned my car. I replaced the struts and springs but I still hear the popping sound.
twistedhhhdx625
  • Guest
poping sound
« Reply #3 on: October 13, 2004, 03:01:00 PM »
well thats reassuring...lol. i guess its just one of those quirks that we have to deal w/. i also was wondering if it could actually be the control arm itself. is that possible?
capri man
poping sound
« Reply #4 on: October 24, 2004, 05:21:00 PM »
I TOO HAVE HEARD THE SAME SOUND IT CAME UP FOR ME AS A LOWER CONTROL ARM BUSHING STILL IM LOOKING TO FIND OUT WHERE I CAN GET THEM ANY ONE HAVE ANY IDEAS? ALAN
Bill D
poping sound
« Reply #5 on: September 10, 2006, 07:12:00 AM »
I am having this same problem and I have found the culprit.  It is the control arm bushings, or lack there of.  The control arm is moving when you brake, forcing  the axle to hit inside the tranny.  But the big question is:
WHERE IN THE WORLD CAN WE GET THE BUSHINGS????
Have found a website with a lot of universal sizes   http://polybushings.com/pages/bushingsbysize.html   but I don't know the sizes since the bushings are gone.
need4speed428
poping sound
« Reply #6 on: September 10, 2006, 09:18:00 AM »
I've got an answer for you....
Front lower control arm bushings.
http://www.globalperformanceparts.com/product_info.php?products_id=19221
Here are the trailing arm bushings if anybody needs these..
http://www.globalperformanceparts.com/product_info.php?products_id=19092
I can't find the rear control arm bushings. I have the part number from superpro if you really need that part maybe someone that deals with superpro could order them for you. The part number is (spf103rk)
To the moderator....this might be a good post to make sticky with those links to the hard to find bushings in there.
2007 Toyota Tacoma 4x4
1966 F100
Bill D
poping sound
« Reply #7 on: October 04, 2006, 03:34:00 PM »
Ok, I ordered the bushings, lets hope they work!!!  And also, I am going to get the sizes of them so I can find the ones from the other site I linked to above so we can get them CHEAP!
Yuri
poping sound
« Reply #8 on: October 02, 2007, 12:36:00 PM »
Thank god i found this thread, i need bushings..... they're like..... gone. Too bad they're out of stock tho
Yuri
poping sound
« Reply #9 on: October 03, 2007, 05:29:00 PM »
ya, the place i went to wanted $500 to do it... so now i gotta figure out where to get the bushings, and how to change them myself.
poping sound
« Reply #10 on: October 04, 2007, 04:24:00 AM »
Hey Yuri! Did you actually find the bushings bad? In one of my cars I found the spot welds separated where the front frame and body come together I had to put the car on jack stands and bring things into alignment with a floor jack and then run several short beads of mig weld to keep it together. It had taken me several looks to find this, I had to scrape a lot of under coating away to see this. Gus.
poping sound
« Reply #11 on: October 04, 2007, 10:03:00 AM »
Begin lubing the front bushing bolt long before you decide to change them. Its held into the frame by a squarenut. The squarenut is only held into place by a shitty stamped steel cover, it bends out of the way when you put too much stress on the bolt (ie when its rusted a bit). These things are inside the framerail so they're near impossible to hold still.
Ive spun those nuts on all 3 capri's that I've owned. Lubing the threads on it with penetrant really helps out, and can prevent problems. On the ones that have come loose from the cover I've had to weld the stupid nuts into place, thru the tiny access ports behind the bushing. No fun.
poping sound
« Reply #12 on: October 05, 2007, 10:21:00 PM »
Hey Rocketman! we need more suspension discussions such as those in the 323forum on Nissan Pathfinders. Wouldn't you agree? Gus.
poping sound
« Reply #13 on: October 06, 2007, 05:54:00 AM »
We could use some more in depth tech discussion but unfortunately most of my knowledge lies under the hood as opposed to behind the wheels. Some of the 323 guys really know what they're doing so I usually go to them if I need help.
Yuri
poping sound
« Reply #14 on: October 11, 2007, 05:15:00 AM »
i believe that i've figured out what my popping sound was... i was under my car last night, and i grabbed and pulled a random bar that i could see... and POP, i found the source of my sound. There's a support bar whose bolts came loose, i'm going to tighten it down to see if it stops my problem.
here's the bolt that loosened up
http://i180.photobucket.com/albums/x298/grantgorgen/Photo0254.jpg
and this is the other end of said bar
http://i180.photobucket.com/albums/x298/grantgorgen/Photo0255.jpg
Pages: [1] 2 3
