Pages: 1 [2] 3 4 ... 7
Author Topic: My capri.  (Read 27463 times)
STE_6000
    • http://teamcapri.com
My capri.
« Reply #15 on: September 13, 2007, 02:37:00 PM »
this weekend i will finish my little project, then ill show some pictures, and then get onto my next project.
Anthony
-Tinted Windows 20%
-Volant Cold Air Intake
-Corsa Exhaust
STE_6000
My capri.
« Reply #16 on: September 16, 2007, 06:40:00 AM »
The work is finally done. pictures to come tonight when i post them up.
Anthony
-Tinted Windows 20%
-Corsa Exhaust
STE_6000
My capri.
« Reply #17 on: September 16, 2007, 03:29:00 PM »
Here is my past 2 weekend project. 300b1 D-Class Rockford amp rated at a 1228max watts, 2 stage 2 DVC Rockford punches, and a pair of Punch Tweeters all in a customer box that I designed and built myself. took one whole day to measure up my back seat area and come up with a layout. 2 days to cut it all and fix it, then one day to carpet and mount it. Looks great in the car and sounds great. And yes, for you  audio fans, you at max power you can hear these things over half a mile away.
Anthony
-Tinted Windows 20%
-Corsa Exhaust
Heavensheros
My capri.
« Reply #18 on: September 17, 2007, 03:20:00 PM »
hey were did you get the bubble top with the head rest cut outs ? and nice speaker set up imm doing that once i get the bubble top also how much trouble / cost was it to do the y pipe ?
1992 Capri XR2
RocketMan VAF adaptor
Accel wires
Irundium IX
2.5\\" Thrush exauhst
Rocket Chip
Rims
H&R Lowering Springs
Tuner FX Racing seats
Gauges w/ A-pillar gauge pods
Accel superstock coil
FMIC
Heavensheros
My capri.
« Reply #19 on: September 17, 2007, 03:25:00 PM »
also what would you charge to make another one of them boxes that will fit into the car if your up to it
1992 Capri XR2
Accel wires
Irundium IX
Rocket Chip
Rims
FMIC
STE_6000
My capri.
« Reply #20 on: September 18, 2007, 12:50:00 AM »
bubble top was imported from the aussie land. the one made in the USA just is a completely flat piece behind the back of the front seats.
y-pipe for exhaust with a full cat back system cost me nothing, ppl locally did it for me before a car show. but they said it would be roughly 150-200, they made the glasspack muffler for me, it is not a store bought one.
The box took me 4 days to work with, i just really took my time. cost? few hundred like if you were to buy it in the store. would i build another? probly not cause it was a pain to work with and i do not get alot of time to do this kind of work normally. last 3 weekends i did stuff for my car, before that was almost last year. Now that i have a new nephew that is living with me that is currently only 1.5 weeks old, im not sure if ill be even doin a project this weekend, but will see cause i do have plans.
 [ September 18, 2007, 07:56 AM: Message edited by: STE_6000 ]
Anthony
-Tinted Windows 20%
-Corsa Exhaust
Heavensheros
My capri.
« Reply #21 on: September 18, 2007, 09:54:00 AM »
ok cool i dont think i will be able to y pipe my capri becouse imm am going 2.5 catless turbo back and do you have like a site or somthing that i can order the bubble top from ?
1992 Capri XR2
Accel wires
Irundium IX
Rocket Chip
Rims
FMIC
STE_6000
My capri.
« Reply #22 on: September 18, 2007, 10:45:00 AM »
actually a turbo capri can run y-pipe fine. its the single pipe of the engine, and it splits after the muffler. The place I order the bubble top and also the spoiler from is  S.S.V..
Anthony
-Tinted Windows 20%
-Corsa Exhaust
My capri.
« Reply #23 on: September 18, 2007, 03:55:00 PM »
Josh! Like Anthony stated, you'll bring the exhaust from the down pipe back to behind the rear axle and then wye it with one pipe coming back and the other swinging over to the driver's side. Then you may want to weld on some fancy tips as the pipes peak out from under the rear bumper. Go to a speed shop and look at what is available for tips, let your imagination run wild. Go to a competent muffler shop and tell them what you want. Get a quote and if its out of budget then go elsewhere check prices. I had one of my cars done about four months ago. I went 2 1/2 from down pipe same size cat and same size muffler and after the axle I swung the exhaust over to the center and brouht it out with a wide flat tip. Looks and runs great! If I could figure how to post pictures I'd show it! Good Luck! Gus
My capri.
« Reply #24 on: September 18, 2007, 03:57:00 PM »
Josh! P.S. that exhaust system cost me 400 bucks installed.
STE_6000
My capri.
« Reply #25 on: September 19, 2007, 10:07:00 AM »
ppl post pictures in there replys and post using image url links. so store the image on a website and enter the url in the post. if you want your car in the gallery section, just email me the pictures.
Anthony
-Tinted Windows 20%
-Corsa Exhaust
Heavensheros
My capri.
« Reply #26 on: September 19, 2007, 11:52:00 AM »
thank you and i got an estamite to get a 2.5 catless turbo back with a thrush glass pack for 350 if i provide the muffler and the muffler is 20 bucks better than flowmaster becouse flowmaster actually restrics air :-( and thank you ill let the muffler guy know about the y pipe thing
1992 Capri XR2
Accel wires
Irundium IX
Rocket Chip
Rims
FMIC
Yuri
My capri.
« Reply #27 on: September 20, 2007, 04:15:00 PM »
think u could do a write-up about the design and perhaps some plans?
STE_6000
My capri.
« Reply #28 on: September 20, 2007, 04:18:00 PM »
i can post up some basics, and let the maker who uses the idea figure out the problems of the car that I had to    leave something in there for fun, i think that is the best thing about doing custom jobs. is figuring out what all needs to be done, to do it right.
Anthony
-Tinted Windows 20%
-Corsa Exhaust
Yuri
My capri.
« Reply #29 on: September 21, 2007, 11:27:00 AM »
me, being the insane kid that I am, would not only put in some Cerwin Vega subs, but also some 6x9's and tweeters in that box. Keeping the 6.5" in the doors too. Can't forget about amps, 2 or 3 needed back there, and as always, a sexy capacitor for each amp with an LCD voltage display showing on the box. That would just rock.
