You should be boosting 7-9lbs stock as it is right now.
You can run to 10psi or so with everything else stock. Higher boost you'll need a chip for the ecu (allows up to 16lbs) and a better intake, exhaust, blowoff/bypass valve
We're here to help ya, let us know what you want to do. Keep in mind it won't be cheap, although its a lot cheaper than other cars bang for buck wise.
