Author Topic: Please help me find and understand BOV..  (Read 5038 times)
randyshear
    • http://www.a1title-42.com
« on: June 10, 2009, 06:37:00 AM »
I have been told by several people I need to upgrade my BOV, along with upgrade the ECU, and add a boost controller.. What is a BOV?? I found mine, it is very small, has a vacuume hose attached, and 2 bigger hoses.. Below is a BOV I found on eBay.. Can you help me understand the BOV, and what I should buy, and how to install it? I am not made of money, so I can't afford to spend a lot.. Thank you all again.
http://cgi.ebay.com/ebaymotors/Turbo-BOV-Blow-off-Valve-Adapter-pipe-3-B_W0QQcmdZViewItemQQ_trkparmsZ65Q3a12Q7c66Q3a2Q7c39Q3a1Q7c72Q3a1171Q7c240Q3a1318Q7c301Q3a1Q7c293Q3a1Q7c294Q3a 50QQ_trksidZp3286Q2ec0Q2em14QQhashZitem3ca262e21eQQitemZ260422427166QQptZMotorsQ5fCarQ5fTruckQ5fPartsQ5fAccessories
-Randy Shear
JackRobot
« Reply #1 on: June 10, 2009, 06:53:00 AM »
That would be fine for you, but adding it without a hardpipe intercooler kit will make this harder. Sinnce your using the stock intercooler the piping is much smaller, and harder to adapt to. But you could always weld the bung on the stock aluminum intake pipe.
Basic description the bov releases boost pressure so it cannot travel back to the turbo and try and force it to turn backwards causing damage.
I saw rici saying something about how he used the stock recirculation valve, as well as an aftermarket bov, in different spots on the charge tube, but you'll be fine with just a bov.
1991 Mercury Capri XR2 - Project car
1991 Mercury Capri XR2 - Daily driver
1986.5 Nissan Hardbody project minitruck
randyshear
« Reply #2 on: June 10, 2009, 08:46:00 AM »
Is there a hard pipe kit for there? Posible a better intercooler as well? If so, where can I find the parts? That is my biggest problem.. I can't find parts.. What kind of BOV should I get?
-Randy Shear
JackRobot
« Reply #3 on: June 10, 2009, 08:48:00 AM »
Check out my build thread, gost also used the same setup as me.
« Reply #4 on: June 10, 2009, 11:10:00 AM »
you can use any universal hard pipe kit. or intercooler. you want... you need to cut the pipes to fit. and use silicone couplers to fit them together.....
this is a intercooler and hard pipes (universal)
for 159.00 shipped, i found on ebay...
http://cgi.ebay.com/ebaymotors/CXRacing-28x7x2-5-Intercooler-piping-kit-JETTA-V6-VR6_W0QQitemZ190312359101QQcmdZViewItemQQptZMotors_Car_Truck_Parts_Accessories?hash=item2c4f8024bd& _trksid=p4506.c0.m245&_trkparms=65%3A12%7C39%3A1%7C72%3A1171%7C240%3A1318
this is where you get to make your car unlike any of ours... theese are a true custom part of building theese cars...
this is my setup.....
now remember one rule to fitting hard pipes...measure 3 times and cut once....
 measure and use a sharpie to mark where to cut your pipes. and try to make as Few joints as possible... (use long pieces if you can)
 masking tape works wonders to make straight lines arround piping... i use a sawsall but ive done alot of kits.. but you can use a hacksaw with a vice to be more accurate...
anything else that pops into mind just ask....joe
« Reply #5 on: June 10, 2009, 01:07:00 PM »
ya we bought a different set though. comes with different pipes and came with a BOV as well.
205 shipped.
we both ran it different ways. you will need someone to tig weld your upper pipe. i paid someone 50 bucks to make mine.
check out my photo set for my set up. took about 3-5 hours to do. i also removed all my A/C parts as well while i was in there.
you will also have to get 3 more hose reducers. 2 on the turbo and one on the VAF
« Reply #6 on: June 10, 2009, 01:08:00 PM »
« Reply #7 on: June 10, 2009, 01:08:00 PM »
« Reply #8 on: June 10, 2009, 02:43:00 PM »
gost, you have a 323gt radiator in your car...did you know???
my capri has plastic end caps and is made of aluminum but my 323gt had the same exact one you got in your car.... just noticed and didnt know if you knew, or if you or the previous owner changed it .... cool
« Reply #9 on: June 10, 2009, 03:16:00 PM »
in the car when i got it...
the passenger side bracket was cut to hell when i got it. i think they had something else in there before. i got the bracket from russ. i eventually will get a all aluminum radiator sometime
« Reply #10 on: June 10, 2009, 04:42:00 PM »
im switching to a civic or integra unit sometime....
i need one big enough to run my 14in fan on... see, i use a huge low profile fan and mount it to the front of the radiator as a pusher, wich is less efficient hence y i use the biggin....
« Reply #11 on: June 10, 2009, 05:18:00 PM »
why is a pusher fan less efficient?
i would think it would be the same. i was going to do the same thing and get a dual fan set up when i did the radiator on the front side in between the intercooler and radiator.
« Reply #12 on: June 12, 2009, 04:47:00 PM »
when mounted on the front.. a fan reduces the radiators surface area, and the wind dosent hit those spots when the fan is not running..... the fan blocks some wind make sense?
