Author Topic: bigger radiator  (Read 3546 times)
Heavensheros
bigger radiator
« on: July 05, 2010, 04:28:00 PM »
looking to get a bigger radiator for the car and was wondering what would be a good replacement like the one rci got if he reads this.
1992 Capri XR2
RocketMan VAF adaptor
Accel wires
Irundium IX
2.5\\" Thrush exauhst
Rocket Chip
Rims
H&R Lowering Springs
Tuner FX Racing seats
Gauges w/ A-pillar gauge pods
Accel superstock coil
FMIC
bigger radiator
« Reply #1 on: July 06, 2010, 12:26:00 PM »
well i did finally, after searching peoples engine compartments for months find out the original app, for my big assed radiator...
(gost will love this) its from a 95-99 eagle talon/mitsu eclipse... back when i was considering trading my buddy for his talon i noticed some similarities and sure enough we parked the cars side x side and there identical
so now thats injectors, turbo and aluminum radiator from a mitsu...
but anyway, yea an aluminum radiator from whatever should work.. a civic half radiator should be plenty there dual core and would allow extra room in the front of the engine compartment
as for how to mount it in the car...good times...
bigger radiator
« Reply #2 on: July 06, 2010, 04:50:00 PM »
you know i was thinking the same thing..i had my xr2 one and the eclipse one and they looked really close...
you can get a CXRacing one with fans and shroud for like 230 shipped....
Heavensheros
bigger radiator
« Reply #3 on: July 06, 2010, 04:53:00 PM »
well i just need a better radiator because my car is running hotter than i want the thermostat is a 160 and car is pushing 185-190 in this hot summer heat.
1992 Capri XR2
Accel wires
Irundium IX
Rocket Chip
Rims
FMIC
Heavensheros
1992 Capri XR2
Accel wires
Irundium IX
Rocket Chip
Rims
FMIC
Heavensheros
bigger radiator
« Reply #5 on: July 06, 2010, 04:58:00 PM »
never mind i might have answered my question
***ATTENTION: DISCLAIMER!!***
    * This item is produced for off-road or show purpose only. This item is not suitable for regular driving. User must follow the direction given and any misuse of this product is at his/her own risk. The Manufacturer, Distributor, and retailer will not be held responsible for using this item other than specified above.
1992 Capri XR2
Accel wires
Irundium IX
Rocket Chip
Rims
FMIC
Heavensheros
bigger radiator
« Reply #6 on: July 06, 2010, 05:21:00 PM »
after doing lots of internet hopping i think i might just get this dual 12" electric fan setup and that might help out the radiator a lot.
1992 Capri XR2
Accel wires
Irundium IX
Rocket Chip
Rims
FMIC
bigger radiator
« Reply #7 on: July 07, 2010, 01:30:00 AM »
i had to take my 180*thermo out becuase in the fall and winter my car never heats up properly..
i have a stock 195* in there now and it stays cool yet lets the engine heat up properly..
the good thing about buying fans for the radiator you have..
 is that later on down the road you can upgrade to an aluminum unit and still use your new fans
nothing cools like an aftermarket aluminum radiator...
 the reason for the disclaimer is that there fragile... the fins bend if you touch them..
 if there wasnt a front mount in front of it im sure debris may hit mine but it dosent and my FMIC is amazingly, pretty rugged...
i didnt really switch mine out becuase my car was getting hot... i poked a hole in the stock one while changing out a turbo.. my buddy had this one lying arround the garage... and it happens to be an aftermarket radiator for a
95-99 eclipse...
bigger radiator
« Reply #8 on: July 07, 2010, 01:44:00 AM »
i removed my ac and mine ran super cool. even in the 115deg temps here in az...that condenser blocks a ton of air.i only ran the main fan and had it on all the time.
bigger radiator
« Reply #9 on: July 07, 2010, 03:28:00 AM »
The stock rad isn't bad, i've seen so many types of OEM capri radiators too. There are some really nice thick core all-metal radiators out there.
I bought a civic half-rad, and I'm not pleased with how small it is. The in/outs are the wrong size too, and the bottom one will need relocated.
I haven't written if off yet, but I gotta do some thinkin before I install it.
bhazard
bigger radiator
« Reply #10 on: July 07, 2010, 04:17:00 AM »
Im running a stock festiva radiator. Its tiny. It hasnt overheated once though. Even in the 90 degree heat. Im also using the condenser fan from the capri.
Granted, I havent gotten stuck in traffic or anything, but if I did get stuck I would probably shut off the engine to save gas. I havent really done any sort of endurance runs either.
