Tech, Repairs, Upgrades => Capri XR-2 89-94 => Topic started by: Heavensheros on April 15, 2008, 03:21:00 AM
Ok imm taking the turbo out of my capri to port out the wastegate finally got good weather to do it and i cannot find the gaskets for the turbo were do i get them and also what other gaskets do i need besides the exauhst manifold and intake manifold ?
Ok seems that i found the gaskets online so thats a good thing and i got exauhst manifold gasket is that all i will need ?
Advance Auto will have it, it'll be special order (next day) and it will run you about $60
i went to advanced auto they said they would have to order it factory direct 2 weeks or go to a dealer the dealer said that they did not have any so i then whent to murrys said they didnt have any and would have to order factory direct but then i decided to check murry online they have it for 33 bucks next day so i am happy and in the manual imm using for this work it sais replace exauhst manifopld gahsket i got them and then it sais the following and i dont know what gasket this is ... : position new gasket and install 2 retaining bolts on coolant bypass tube outlet . what gasket is that ? and thank you for all the help everyone this work should be going on this weekend
It's the gasket between the water pump outlet or inlet, I can't remember but it's really unnesecary, I didn't replace mine and have no coolant leaks or anything,
