Depends on what bolts you took out, and what they were holding in & if anything fell inside. Some of the bolts retain the shift linkage, springs, ball bearings, detents, etc. Some won't do anything if you pull them out
RC: There is no differential gasket. The two halves of the transmission case are sealed with a thin bead of RTV sealant.
